  • Guests: 30
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
Simple regulated 3V->400V step-up converter
radhoo
Fri Jul 18 2014, 06:38PM Print
This is perfect for building a Geiger Counter.
Just a feedback oscillator, a ferrite core transformer, a rectifier and a regulator using zener diodes and a second blocking transistor:
300x98 300x177
It uses little power, has good efficiency, and a perfectly stable output:
300x199 300x199
Full construction details are available here: Link2 . I've presented sufficient details to cover building the ferrite transformer, and pics to exemplify.
Eagle circuit details and the PCB as pdf attached: Link2
I've used 3x120V + 2x16V Zeners, and measured 384V output. A good value for a Russian Geiger tube.
Linas
Fri Jul 18 2014, 06:55PM
why you need so much power or using so large construction, just like in SSRS ?
This is 3V to 400V converter, it is plentiful for any Geiger tube :), and yes, it is regulated
1405709731 1143 FT164825 1
radhoo
Fri Jul 18 2014, 07:23PM
Ok Linas, I accept your challenge :). See this: Link2
150x150
But the idea about this circuit, was to make it easy to build. So no SMDs and a lot of space :)
Linas
Fri Jul 18 2014, 08:57PM
radhoo wrote ...
150x150
SMD parts with proper mask is much easier to assemble for large quantities,and converter like this cost at OSH would be in few $ range
