  • Guests: 34
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Light LED with 4 nanoamps
johnf
Sat May 09 2015, 07:40AM
Try VR68 range resistors they are very cheap max value 68 meg ohms
element 14 RS etc carry them
Tony Matt
Sun May 10 2015, 12:45AM
Why not try first without the resistor ?
If it not work without resistor, you do not need order the resistor ...
Zamboni
Wed May 20 2015, 11:52PM
Zamboni Registered Member #2836 Joined: Fri Apr 30 2010, 01:24PM
Tony Matt wrote ...
Here the schema more readable...
1429677581 3700 FT163929 Zamboni 2
I got the parts from Mouser and hooked it up. It does not really work. There is a tiny flash, but it is even dimmer than hooking up a regular 10MM LED between the negative terminal and the battery.
As I looked at the setup, another problem became more pronounced. The battery really does not like being hooked up to the capacitor. I noticed that the direct short of the battery and the capacitor is not for a moment or two, but for nearly the entire time. The battery is charging the cap until the spark gap fires, then charging again. That is the same as having a dead short the entire time.
That won't work.
So far, the only thing that can be hooked up "dead short" fashion is an electrostatic volt meter. The Tera-ohm resistance prevents the battery from "feeling" bad. smile
The other suggestion that uses a capacitor suffers from the same problem.
I really appreciate all the assistance that the forum members have provided, but it looks like it can't be done without harming the battery.
I did notice one very interesting thing. I will probably start another thread that describes a small, but interesting thing that happens when I have a 10MM LED hooked up after the negative terminal and before the negative terminal of the battery. The swinger delivers the 4 nanoamp charge to the negative terminel, the charge lights the LED (very dimly), then the swinger returns to the positive terminal to gather more charge. What is interesting is that when the, now depleted, swinger touches the positive terminal, the LED blinks again. That surprised me. It seems very interesting.
Again,
Thank you for all your assistance,
Paul
Thu May 21 2015, 01:57PM
You could still try limiting the current to a few nano-amps with resistors, but you'd need a very low leakage capacitor.
If I had suitable resistors I'd try this with a Leyden jar, for example.
EDIT: Some form of 'water resistor', or even 'salt water resistor' might be worth looking into wink
Antonio
Thu May 21 2015, 10:14PM
The capacitor is there to accumulate energy to flash the LED more brightly. There is no way to light a LED without consuming energy, of course. Resistors would not help. They would consume energy and reduce the energy delivered to the LED. Please provide a drawing of the system where the LED blinks when the swinger touches both terminals. Try a neon lamp instead of the LED.
Zamboni
Wed May 27 2015, 12:53AM
Antonio wrote ...
Antonio,
The setup where the light flashes each time the swinger touches one side or the other is the older setup. It is the one where the LED's are attached between the negative swinger terminal, and the negative battery terminal. I have enclosed the original sketch, The only difference is that there is no capacitor or spark gap.
To be very clear, the flash occurs as the swinger touches either the negative terminal, which would be expected, or the positive terminal, which seems very strange to me.
I have tried a neon. It works OK, but just like the LED, too faint to be of any use...except in the dark, where you can barely see it.
Paul
1432688032 2836 FT163929 Paul
Tony Matt
Fri Jun 05 2015, 11:21PM
Zamboni,
Tell us the polarity of the hi voltage diode and polarity of the leds.
Regards
Antonio :
How about using similar arrangement of Bennet Doubler ? Nicholson Doubler ?
Antonio
Sat Jun 06 2015, 01:45AM
With this schematic, the LED may really light up when the pendulum touches both plates. When it touches the negative plate, the charge that comes from the pendulum goes through the LED. When it touches the positive plate, the charge that goes to it comes in part from the negative plate, passing through the LED again. The effect is possibly more interesting with two LEDs, one at each side of the battery.
I could try to make the same using an electrostatic machine, as the rotating doubler of a previous video.
1433555033 834 FT163929 Pendulum
Zamboni
Sat Jun 06 2015, 02:06PM
Antonio wrote ...
Antonio,
Your explanation makes perfect sense. No big mystery after all...just lack of knowledge on my part. wink
Thank You,
Paul
Antonio
Mon Jun 08 2015, 01:16AM
I tried a similar setup using that machine of the video as power supply. The pendulum works without problems, but I didn't see any light with LEDs or neon lamps at the pendulum touches. My pendulum was small and with a different geometry, however. It's also difficult to keep well regulated the voltage produced by the machine, and the neon lamps had a tendency to light dimly following the ripple in the voltage. The voltage was higher too, probably around 2 kV.
