  • Guests: 28
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
Thrust Stand and Propeller Modification.
Sat May 31 2014, 05:16AM Print
Purpose and Goals:
First, to evaluate categorically the propellers being used for multirotor use, using tables.
Second, to confirm or invalidate power reduction by cutting propeller tips back, (high mass low velocity change props).
Third, make much better estimates on duration of flights for a given battery mass.
*NOTE: there is one premise above all others i want to prove or disprove. that as blades get wider, steeper in pitch but shorter in radius they produce thrust at lower overall velocity change in the slipstream (given constant power input and RPM).
1401513386 2431 FT0 Thrusttay
the overview of the test stand.
1401513529 2431 FT1630 Meter1
I have two of these, one will be used so i dont need my fingers near the prop, the other will be modified to output with a BNC connector to a O-scope.
1401513529 2431 FT1630 Meter2
It appears to be just a generic 8051 microprocessor.
1401513790 2431 FT1630 Meter3
if you look , youll see a LM358 IC near the PD. i wonder if i should take the output from there?
1401513790 2431 FT1630 Meter4
1401513906 2431 FT1630 Meter5
Dr. Drone
Sat May 31 2014, 05:57AM
shades
Sat May 31 2014, 06:34AM
Dr. Spark wrote ...
I like the pressure transducer. cheesey
So is this to test motor vs prop vs current something like this Link2
Rgs,
Web @ Link2
Vids @ Link2
Occupation: Retired
Lifestyle: Biker
"Old cowboys never die. They do, on occasion, have to reload "
yep, then i can post real in depth data.
volts, amps, watts, RPM in increments, prop pitch, prop dia, force, throttle increments, velocity of flow.
EDIT: im also trying to figure out derivatives for each prop maker, each prop, and in the categories of:
derivative of radius as dV/dR (velcoity/radius)
derivative of mass as dR/dM (radius/mass)
derivative of thrust as ??? power in? maybe?
but i need to look at my calculus book and sober up some...
Sat May 31 2014, 07:53PM
1401564245 2431 FT1630 Flow1
pdf pic, this is always what i imagined the flow geometry to be.
