  • Guests: 9
cbfull (52)
Steve Ward (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
10W Push Pull Tube Amp [updated with testing]
Wed Apr 02 2014, 10:29AM
Heater wiring and layout of the amplifier looks good, seems many best practices are used to ensure low noise.
The grounded screen on the input signal cables should maybe be grounded on the bar too and not at the chassis to avoid making antennas far away from the ground bar. The copper of the screen is also connected through the bolt/nut and not directly to the aluminium chassis. Other than that, good star grounding :)
The design could properly need some upgrading to modern times, f.ex. get rid of all electrolytic capacitors that are not in the power supply.
These punches are all very tiny small things, because you already did a great job!
Good looking little amp and the glow pictures are always the best :)
tobias
Thu Apr 03 2014, 12:55AM
tobias Registered Member #1956 Joined: Wed Feb 04 2009, 01:22PM
Thanks guys!
Steve, did you notice any difference between +40 V and the cathode bias?
Mads, very good tip on the Screen cable! Very easy fix too, will do soon =)
What capacitor would you use to replace the electrolytics on the tubes? They are paralleled with Bias resistors.
Thu Apr 03 2014, 09:14AM
tobias wrote ...
Yes, a huge difference. The amp using +40V was a hi-fi amp and the one using cathode bias was a guitar amp. smile
tobias
Thu Apr 03 2014, 10:42AM
Well 40V it is then. Will have a resistor divider instead of a songle bleed resistor for the big filter cap on B+ and reference from that.
tobias
Fri Apr 18 2014, 10:36PM
First post updated with testing shots.
I did not want to mess around with resistors so I just referenced the heaters to 0 V.
The day I change it to 40 V I will test again to see if it improves something =)
Thu Jul 03 2014, 06:36AM
tobias wrote ...
You should also do a frequency response test on your amplifier, if you look here: Link2
at my updates from 19th December 2013 and 4th January 2014, it is described how to do it with a oscilloscope.
