  • Guests: 29
Steve Conner (46)
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Rapid firing EM accelerator
Bruhathkayo
Tue Dec 10 2013, 06:35PM Print
Bruhathkayo Registered Member #6571 Joined: Mon Sept 10 2012, 10:57PM
Is this possible? What would be the best method? Coilguns or railguns?
Yandersen
Thu Dec 12 2013, 09:00PM
The coilguns are more common. Rapid firing ones exist already, but the designs are based on LiPo batteries. Those are toys power-wise, because batteries are not designed for megawatt pulses - this power can be drawn from capacitors only. So high-power rapid-fire coilguns haven't been made so far. If you want to be the first one to try, consider half-bridge design. Will you dare?
