  • Guests: 73
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
CPU, graphics cards ,FPGA, multi pics/audino speed
Andy
Fri Dec 06 2013, 08:31AM
Hi, created a ramdisk speed it up from 1.16min to 59sec. The number of combinations I think might be to high, its 10 chars from 0 to 0xff. I read somewere that 10chars for md5 hash is doable with the right setup, I think they use graphics cards, below is some of the code, apart from asm i'm lost how to speed it up?
for(;hexq[8]<0x01;) {
if(hexq[0] > 0xff) {
hexq[0] =0;
hexq[1]++;
if(hexq[1] > 0xff) {
for(i=1;i<=7;i++) {
if(hexq[i] > 0xff) {
hexq[i] = 0x00;
hexq[i]++;
if(type1 < i) type1 = i;
for(s=0,eip=0,pie=0;s<1;s++) {
if(hex[i] > 100 && hex[i] <= 200) goto ten;
if(hex[i] > 200 && hex[i] <= 300) goto ten1;
if(hex[i] > 300 && hex[i] <= 400) goto ten2;
if(hex[i] > 400 && hex[i] <= 500) goto ten3;
if(hex[i] > 500 && hex[i] <= 600) goto ten4;
if(hex[i] > 600 && hex[i] <= 700) goto ten5;
if(hex[i] > 700 && hex[i] <= 800) goto ten6;
if(hex[i] == 0) {
do something
fprintf(data)
goto bot;
if(hex[i] == 1) {
do something
fprintf(data)
goto bot;
Carbon_Rod
Fri Dec 06 2013, 10:35AM
I recommended a dynamic programming abstraction given your algorithm has some overlapping subproblems (you add the same numbers many times in this example). However, you are skipping over some crucial steps by attempting to find more complex ways of permuting through W(k*n^3), rather than solving the actual problem.
ASM can be faster, but in most cases it is not due to architectural and automatic code optimizations of modern C/C++ compilers.
Best of luck,
Rod
Shrad
Fri Dec 06 2013, 06:58PM
replace < and > with a mask
a good thing would be to use a single binay mask and << or >> the mask or the number to crunch
it is easy to see if a number is higher than a multiple of 2 with a mask, and increment this value either by the mask or the value with a pad by 2 operator
Andy
Wed Dec 11 2013, 06:02PM
Thanks you three for the help, The projects on hold, I let to much dust cover the cpu heat sink, and have fried it :( , but its mostly done
