  • Guests: 37
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Coil Gun Chassis Project
sheepdog
Wed Nov 13 2013, 04:29AM Print
sheepdog Registered Member #39221 Joined: Sun Oct 27 2013, 05:22AM
Hi all my first post and Coil Gun Project. I am going to build a chassis first in such a way that you can just change out the guts without building the whole weapon each time. I know this is backwards probably but Firearm Design and CNC machining is my strongpoint. I'm here because I am weak in electronics and would like to get some feedback on benchmarks.
I have a question what would be the max projectile velocity I could hope for using a large squad automatic size weapon such as the US m240 or the Russian PKM utilizing an additional backpack to house an energy source?
Thank's Mark
DerAlbi
Wed Nov 13 2013, 06:06AM
We cant give you a velocity, but maybe an energy. Also, since real weapons are not part of the culture in civilized countries i cant get any data from your weapons description.
However you can estimate this by yourself: without electronics knowledge you will have an energy transfer efficiency of about 2-5% as a startingpoiint. higher projectile mass tends to be on the 5%-side.
You now can search for HV-Caps (350V+) Look at their dimensions and capacity, calculate their stored energy (E = C/2*U^2) and use the 5% rule of thumb.
Take also into account that you also need a permanent battery and a charging circuit.
Using a battery only (low voltage on coils) will not satisfy you without complicated electronics - and this is not a beginners project at all.
btw: backward design will allways suck. to get any noticably power out of a coilgun (and actually you called it a "weapoin" cheesey) it should be highly optimized: for power, not form factor.
But it will be a nice project. just dont expect too much.
