Registered Member #96
Hi, just found these. For Dell mini9, SSD miniPCIe 64GB for under £50. Its a PATA, based on the miniPCIe ie basically the same as the connector used on most if not all WiFi cards and has half decent speed compared to my benchmark SDHC. I know that the pinout is similar and I've got a bunch of such connectors, so DIYing an adaptor is within the realms of possibility.
Also happen to have a mostly working (needs new BIOS) AOA150 with dual miniPCIe slots which is known to work with these.
EDIT: Only one of the ports is a true SSD, in this case the older machines used IDE whereas the new ones use mSATA with a very similar pinout but sadly not interchangeable. Yet another example of a non standard "standard", if you try to use an IDE SSD in a SATA machine it won't work but some early examples would use a dual standard chip and some sort of autodetect. The Eee 900 actually has both thanks to a firmware update, but the connector wasn't designed to use modern SSDs so some minor mechanical adjustment is needed. To use this in mSATA mode requires some kludge-fu in the BIOS, but it will boot from the onboard SSD as well which is 4GB.
People braver than me have even swapped out the four 1GB chips for pin compatible 4GB or 8GB ones, and used some clever modwiring to bank switch multiple OS images by enabling one of four address modes (00,01,10,11) to enable the chips in turn.
