  • Guests: 14
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Auto-connect to VCP COM port from any USB
Linas
Sun Jun 16 2013, 03:04PM Print
Hello, i am writing program for SPI flash configuration for my ADSP Shark processor,
Idea that VisualDSP++ will generate .LDR file, and my program via USB send it to SPI FLASH with some help from STM32F103.
Since i going to use FT232 chip, i need to know how can i make auto-connect function, since now i am using COMX (X can be any number)
Right now i have select in program right COM port to open it:
system( "MODE COM6: BAUD=115200 PARITY=n DATA=8 STOP=1 RTS=ON DTR=ON" ) ;
 if ((comport = fopen("COM6", "wt")) == NULL)
Does any one know how to make it that it will work with any USB ? ( since changing usb port change COM port number)
Mon Jun 17 2013, 09:38PM
My best guess would be to use the FTDI SDK (even in com-port less mode)
I know they have lots of features, and I assume device search is one of them.
Try to give the chip a serial number, that may keep the com-port fixed.
b.t.w. what are you coding the pc-program in?
