  • Guests: 46
Timo (40)
01/06 Ash Small (63)
01/06 Oatmeal (38)
01/08 Lyonel Baum (77)
MPI programming
Linas
Mon Apr 22 2013, 10:34AM Print
Hello, i have to do homework from MPI and i have no idea how to start, maybe some one can guide me how to make it work
Original problem is from Parallel Programming with MPI book (Peter S. Pacheco )
If you have an implementation of MPI that runs on a network of workstations and the workstations are not all using the same
disk for their home directories, use the file I/O functions to write an rcp function. It should take as input the name of a file and
two process ranks. The first process has access to the file. The second process should create a copy of the file on it's local disk
under the same name
So can i basically use single computer, and with one process open file, and with other process copy to other disc location ? Or how that should be done ?
Andy
Mon Apr 22 2013, 08:19PM
Hi
You could use omp, the OS should take care of dup file handles, each section gets a processor on the cpu
#include <omp.h>
#pragma omp sections
#pragma omp section
File open temp.txt
#pragma omp section
File open temp.txt
File open temp1.txt
