  • Guests: 29
  • Members: 1
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
SSTCs: Input Voltage vs. Half-Wave, Full-Wave, etc...
Thomas
Sun Aug 27 2006, 05:16AM Print
Thomas Registered Member #120 Joined: Fri Feb 10 2006, 07:07AM
I'm just curious as to who runs they're SSTCs at 120Vac then have it half-wave rectified or at 230Vac half rectified? I've been seeing several people in the US running at 230 and others running at 120. Of coarse it's odvious that 230 would have better results b/c of the higher input voltage. But is it necessary? What does everyone advise? Now once again what about the DRSSTCs? Use 230 or 120 full-waved rectified? Whats best? Also how come I get smaller arcs an a full-wave rectified SSTC? Yes I did google this, however, most of everyones circuits don't show the input voltage unfortunately javascript:addtext('!sad',true).
Sun Aug 27 2006, 01:42PM
For SSTCs, i typically run 120VAC or 240VAC half-rectified. For Audio Modulated SSTCs, I use DC input. For DRSSTCs, DC input is most always used.
Marko
Sun Aug 27 2006, 02:14PM
DRSSTC's need DC filtered with big caps to serve as reservoir for pushing enormous currents trough the primary during ON time.
Voltage is your option, you need to double 120V to get around same DC voltage as with 240iVin and etc..
williamn
Sun Aug 27 2006, 02:51PM
williamn Registered Member #55 Joined: Thu Feb 09 2006, 04:56AM
And switching topology, a fullbridge will effectively had double PP output of a halfbridge. So halfbridge and doubler =fullbridge no doubler, fullbridge with doubler= amazed
Marko
Sun Aug 27 2006, 03:37PM
Problem with it is that in halfbridge IGBT's still face full supply voltage, so it may not be comparable with fullbridge with/with no doubler.
For example, fullbridge can work with 320V supply with 600V IGBT's, but halfbridge would need it doubled to 640V for same effects adn IGBT's would pop.
williamn
Sun Aug 27 2006, 05:20PM
Thats the point I was making. Topology is a factor to consider when thinking of input voltage.
Kolas
Sun Aug 27 2006, 05:46PM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
Thomas, i use 120.
I feel that the higher voltage you use in, allows you to use the same power as you would with a lower voltage, but keep the current down. since IGBT's and mosfets tend to disipate more heat when the pwoer is manafested in current.
Halfwave rectification not only lowers the input V to .707*(input RMS) but it also puts a 60 Hz inturuption in for you. (d'oh)
Foder for the brain.
Kolas
Sun Aug 27 2006, 07:50PM
MOD EDIT: Changed Title Thread
*** When choosing a thread title, please choose one that best fits the subject you will be discussing. No one should have to click on the actual thread to find out what the particular thread is about. ***
