  • Guests: 27
Linas (34)
Toasty (29)
05/16 kg7bz (68)
05/16 steve516 (31)
05/17 Finn Hammer (72)
PCB etchant using HCl + HClO?
ZeroHour
Mon Mar 25 2013, 07:13PM Print
ZeroHour Registered Member #9665 Joined: Thu Jan 17 2013, 10:49AM
Hi everyone,
I've been thinking about making an electrolysis apparatus, first only to make sodium hydroxide, but then I realized there are more uses to it.
Firstly, chlorine gas will form at the anode. I thought I could use this to make hydrochloric acid, by dissolving it into water:
Cl2 + H2O = HCl + HClO
Now, it came to me that the HCl + H2O2 etchant uses an oxidizer, being H2O2. Isn't HClO also an oxidizer?
Would this solution be usable as an etchant?
I wanted to use the sodium hydroxide to neutralise the etchant, leaving a copper-free solution and CuO, as seen in this thread.
Secondly, I read in a chemistry book that you can extract the copper from CuO by adding hydrogen gas (Produced at the cathode), like this:
CuO + H2 = Cu + H2O
I'm not completely sure if this can actually be done, please forgive me if this is a stupid question.
Could someone tell me if my train of thought here is correct?
Thanks in advance,
ZeroHour
