Registered Member #10072
I need a reasonable amount of hydrogen for ionization, I was thinking about a electrolysis cell but online there isn't much to do about a pure hydrogen source, because most of what I see is for HHO torches where isolation is not so big. My biggest concern is isolation, an unspecified particle in a cyclotron might provide unfavorable results . I was wondering if two flasks could be used then a line between the two with meg ohms of resistance to stop O from leaking into the other flask. My biggest concern is whether it would do exactly that, and If so, any other good designs?
Registered Member #3888
The setup I've seen used at college looks like an H made out of glass tubing. Valves are at the top of either side to let out the gas, and the electrodes are at the bottom of each side. I suppose you could pack some cotton into the cross bar if you're worried about oxygen bubbling over. It's basically just a glorified salt bridge setup
Registered Member #3414
If you are using electrolysis, you'll need to dry the hydrogen. There are various ways to do this. I think also, for purity, you will need something like platinum electrodes (other types may be suitable, it's a while since I read up on it) There is some useful information on fusor.net, but you may need to 'dig' for it.
I would just get a pressurized gas bottle, 1L bottle (or something) at the flow rates you will need it will last forever. The guys at fusor.net did a lot or work/research into gas feeding and handling, you might want to check it out.
Edit: Another aspect you should keep in mind is that you gas lines should be metal and metal seals only, like Swagelok, elastomers are incredibly permeable at micron and sub micron pressures.
For a cyclotron I assume you are looking at 10^-6 or lower base pressure, basically you should exclude from the start any kind of elastomer seals anywhere.
OK The permeability of Viton though might be a problem as the two main seals on the device are Viton! the Drying process should be achieved by the worm which is placed in dry ice to act as a cold trap.
A cold trap should be ok for removing moisture. There is another common method used, possibly slaked lime, but I'd need to check.
Purging your supply system will possibly not be as straightforward as if you had a pressurized supply. I'm sure it's possible, though, but, for the quantities required, it may make more sense to buy some than to produce your own.
Viton is permeable like hell, I got about 700micron/24hour rise in pressure in my system. Initially I though it's a leak, then I run the numbers and for (my) 110 inches of viton and the volume I have this is close to the theoretical diffusion rate.
I'm considering replacing at least some of them with indium o-rings.
You will want to eliminate as much viton from the system as possible at these pressures.
Any large seals should be the copper/knife edge type.
It's going to be problematic enough using diff. pumps (not impossible, though) without pumping outgassing viton as well.
Ideally, the gas feed line should be all stainless steel, as copper and brass can also be problematic here (again, I'd need to check before going into much detail)
Well I guess indium it is, though it's so d*mn expensive, and hard to find! The setup has changed to a more conventional H design design, though the Vacuum is not on the electrolysis setup, it is separated by a hypodermic needle and about 3ft of capillary tube so the permeability of the rubber in the H generator is not of concern. what kind of electrolyte & electrode materials should I use?
Registered Member #3215
if anyone uses indium seals, I can help them dispose of used ones as it fits my laser needs quite well.. I would laminate and make foils for my vanadates
