  • Guests: 28
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Optical trigger Tuning
1 2 3 4  last
ZakWolf
Sun Jan 20 2013, 08:55AM Print
I just gathered enough parts to start building my 2 stage coil gun and i was wondering were i position the led and phototransiter before the second stage? trigger circuit here Link2
Should it be right before the second stage or slightly before to have time to turn on ?
Yandersen
Sun Jan 20 2013, 11:48AM
Put it right after the second stage - maybe it will shot backwards then?
josh1234
Sun Jan 20 2013, 07:18PM
josh1234 Registered Member #5969 Joined: Mon Jul 30 2012, 09:27PM
put it just before the second stage
ZakWolf
Sun Jan 20 2013, 07:22PM
Yandersen wrote ...
Sweet thanks I will try that :)
josh1234 wrote ...
So no tuning at all ? The circuit is fast enough to sense the projectile and switch on ?
josh1234
Mon Jan 21 2013, 10:47PM
If you are using a SCR you should use Barry's rlc calculator to check you pulse length is not longer then the time it takes for the pregectile to get to the centre of the coil
ZakWolf
Mon Jan 21 2013, 11:49PM
josh1234 wrote ...
to late :( so far the projectile penetrates through an entire card board box when hit with a small hammer to give it a push so hopefully the first coil will be more efffective
Yandersen
Tue Jan 22 2013, 04:03AM
I would put the gate right before the second coil and shorten the projectile a little bit - this way the difference in length will give the second coil some time to turn on and by the time current will rise to required level bullet will reach the point of maximum pull force - this should higher efficiency.
ZakWolf
Tue Jan 22 2013, 05:03AM
So I have been playing around with it and i am feeding the gate of the SCR ~7 volts when it requires only 1.5 i didn't know this was the output and now it only fires when feed a high voltage pulse. Is there anyway to have a higher current pulse at a lower voltage with that circuit and this hurt the SCR ?
thanks i will defiantly post this in the project sections when i start testing completely
Yandersen
Tue Jan 22 2013, 11:37AM
Have you ever heard about devices called resistors?
ZakWolf
Tue Jan 22 2013, 06:30PM
Yandersen wrote ...
No i will have to wiki them...
I dont mind the funny answers but i hope you dont mean anything by them
And after some tunning and tweaking i got the trigger citcuit to rest at .7v an spikes to 2v when the beam is broken
1 2 3 4  last
