  • Guests: 24
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Bifilar Windings - Flybacks
Maxwell
Wed Feb 06 2013, 02:30AM Print
Maxwell Registered Member #8497 Joined: Tue Dec 04 2012, 06:24PM
I've been content with my home-brewed 20W Boost Converter (~50% efficiency) for a while.
I recently acquired a flyback transformer from an old TV.
I'm confused as to dealing with the bifilar winding. It is my understanding that you take a long wire, twist it, then wrap the 'twisted' wire about the primary.
Second - looking at Uzzor's 50W Charger, how do I deal with the wiring of the 47-250uH inductor to the primary?
DerAlbi
Wed Feb 06 2013, 03:15AM
Bifilar: it doesnt need to be twisted if you are using a core. A bifiliar arrangement is just a normal coil wound with 2 parallel wires. ...and of course 4 open ends.
"Deal with the wiring": use a solder iron at 320°C / 600°F...
Maxwell
Wed Feb 06 2013, 03:38PM
That Bifilar part's construction makes sense now.
However, can anyone explain where the lead off of the small inductor connects to the flyback core?
DerAlbi
Wed Feb 06 2013, 09:53PM
..well in schematic it connects to the centertap of your primary...
you are aware that you dont use the bifilar coilat all. arent you? its just the easiest way to produce two equal , but seperated windings. you have to create your own center-tap by connecting the windings at one point.
Maxwell
Wed Feb 06 2013, 11:34PM
DerAlbi wrote ...
Sort of. The issue I'm having is with the picture of his windings. I notice that on the primary side, the center tap is not at a single point - it appears to run through the primary.
I also note that the orientation of the wrap is reversed from 'top and bottom'.
Ash Small
Thu Feb 07 2013, 12:00PM
If I understand you correctly, he's used two wires, one for each 'half' of the centre-tapped primary. The 'centre tap' is actually the centre terminal of the terminal block shown in the last photo. He's used three wire colours and joined them so he can tell which is which. I'd just use two wires myself.
He's twisted the wires together from the terminal block to the 'primary proper' in order to reduce stray inductance, etc.
