  • Guests: 22
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Something worth experimenting with?
Freelancer1331
Mon Dec 31 2012, 01:59AM Print
Freelancer1331 Registered Member #7829 Joined: Sat Nov 03 2012, 08:16PM
Given the cost of high power switching devices, what is the feasibility of not using IGBTs, SCRs, etc. and instead using contacts on the inside of the barrel? The projectile would complete the circuit of each stage as it passes down the barrel and the placement of the contacts could be tuned to achieve maximum performance. Obviously, this design would require some sort of initial kick to get going.
I think Ash Small brought this up in Saz's project thread. What're your thoughts?
Maxwell
Mon Dec 31 2012, 03:23AM
Maxwell Registered Member #8497 Joined: Tue Dec 04 2012, 06:24PM
What you're referring to is spark-gap triggering.
If you're utilizing decent high power (>1kJ) capacitor banks, you can afford the losses from the arcing.
This method has been implemented very successfully by one of the members here who almost broke the sound barrier.
However - the consequences are:
1. Terminal contact erosion caused by arc'ing.
2. Very noisy.
Freelancer1331
Mon Dec 31 2012, 10:39PM
Ah spark gaps! Thanks
Given the breakdown voltage of air, roughly 3kV/mm, and a gap between contact and projectile of say 0.5mm, I'd need 1.5kV for the spark gap to work...
In terms of cost, I imagine high energy capacitors to be as expensive if not more expensive than high current switching devices.
Maxwell
Tue Jan 01 2013, 12:41AM
Do remember that you can place your caps in series to obtain h.v.
Yandersen
Tue Jan 01 2013, 01:44AM
Yeah, and do remember that optical triggering doesn't require h.v. and will work for more than one shot. :)
Freelancer1331
Tue Jan 01 2013, 09:32PM
My current design (on paper) has 3 optically triggered IGBTs at much lower voltage, but I thought I might be able to eliminate some part costs by utilizing spark gaps.
Avalanche
Wed Jan 02 2013, 12:05AM
I wouldn't want to try it cheesey
To get a good mechanical contact, which you'll want for a high current, you'll end up with a load of friction slowing down the projectile almost to a standstill. Switching devices are generally cheap anyway, and have very low conduction losses.. so stick with them! My first coilgun used a mechanical switch, and even that's probably better than including the projectile as part of the switching action. Coilguns are very inefficient (in terms of joules in the capacitor converted to joules in the projectile, 1/2mv^2) that anything that impedes the projectile will just make it worse.
Freelancer1331
Wed Jan 02 2013, 12:29AM
Yeah, I realize the spark gap was just a hopeful attempt to save money and keep performance at the same time (unrealistic). I think I'll take all of your advice and keep to the switching elements especially since this is my first build. Thanks everyone
Legit_bacon
Wed Jan 02 2013, 10:00PM
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
My first coilgun did this, some odd 800volts ish (long time ago) and a spark gap trigured by a relay (single stage) so timing wasn't a issue. Worked really well. The relay never really wore either.
