  • Guests: 25
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
About capacitor ESR
Wizzup
Tue Jan 01 2013, 01:03PM Print
Wizzup Registered Member #3302 Joined: Sun Oct 10 2010, 02:21PM
I thought about buying a 500V 3300uF capacitor but i wanted to know if 38mOhm ESR is good or bad compared to other common electrolytic capacitors? I would use it for a coilgun so would it perform well in that usage? I dont need a long answer here, just if its anywhere near the common ESR values that people use in their cap banks.
DerAlbi
Tue Jan 01 2013, 01:53PM
I think its quite a lot of ESR. However, you are able to source 500V.. so you can also have higher losses^^
You should estimate your Coil-ESR, then calculate the maximum current and chek if you will be happy with it.
There will be a voltage divider with both ESRs.
My 3x 18mF @ 350V in parallel have only 3mOhm ESR... compare it to that^^
Yandersen
Tue Jan 01 2013, 04:21PM
I think 38mOhm is not bad for electrolithic. Worth buying, IMHO.
Tue Jan 01 2013, 05:28PM
38 mOhm for 3,300uF 500V is typical for good electrolytics.
(for new electroytics, measured esr is usually much lower than specifications)
In theory 500V/38mOhm = 13,158 A peak,
so if you operate well below this (say <1000 Apk) the esr should not be a problem.
Wizzup
Tue Jan 01 2013, 09:01PM
How about these caps: Link2
1kJ energy for 29€ is what i could afford but are these caps reliable? It says Nippon Chemi-con on the side of the cap in the picture so it should be good quality, but i read the thread here for the 1000J S.C.A.R coilgun and he had some chinese caps fail so do you think these are the same quality as those? Do you know if anyone else has ordered these caps?
I would for sure buy some bigger caps from other countries than China but the shipping costs to Finland are usually bigger than the cap price when ordered from US for example. The chinese sellers have usually free delivery.
Wizzup
Sun Jan 06 2013, 12:10PM
Sorry for double post, but just wanted to say that i won the auction of 3 pieces of 4700uF 450V electrolytic caps. They are used but look like new and work just as they should. The datasheet says their applications include power inverters and circuits with high impulse current so they should be ideal for coilgun and disc launcher purposes :)
I calculated the total energy of them to be 1428J
Here is a link to the datasheet if someone wants to look: Link2
