  • Guests: 27
Alexandre (32)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
Blown hybrid in Samsung TV :(
Mon Aug 14 2006, 07:01PM Print
Hi all.
Any ideas where I might get one of these? Its a SEC 3S0680R 5 pin "hybrid" regulator chip.
From a Samsung TV, when I replaced the fuse after removing the degaussing posistor that appeared to be the cause, it went BOOM.
Thanks, -A
1155582084 96 FT0 Fried
Marko
Mon Aug 14 2006, 07:09PM
It is not a hibrid; it's Fairchild power switch (®)
Sadly they are gone obsolete..
Mon Aug 14 2006, 07:52PM
um, chips with a high power fet and some low power circuitry are generally considered hybrids wink
In any case, couldn't you just bypass the whole power supply and hack in a new one?
I am guessing that if it blew there is something else that is shorted... Fets don't explode for no reason (well, in commercial equipment at least)
Tue Aug 15 2006, 08:23AM
Yeah. It looks like other parts have blown, but I am fairly attached to this TV (it was only bought at the end of '99) and otherwise worked fine.
Any ideas? i seem to recall that there are companies who supply out of date or obsolete semis.
-A
