  • Guests: 31
Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
Some progress on my MARX
Dr. Shark
Mon Aug 14 2006, 06:40PM Print
Hey guys,
just so you don't think I have given up playing with high voltage alltogether, I got a few picures for you to laugh at:
Stress testing door-knobs
1155580496 75 FT0 Stress
yup, thats the output of my 100kV Cascade arcing across it. The gap is set at something like 7cm (3"), but the 30kV doorknob stood up fine. Closeup:
1155580553 75 FT0 Stress2
The results (not the voltage rating, but rather all the surface tracking across the caps) persuaded me to double up on caps in the prototype marx:
1155580653 75 FT0 Funk
This was probably a good idea, but not sufficient, since it now arcs over all over the place:
1155580631 75 FT0 Arc
Oh, btw, don't be fooled by the rather short sparks: The gaps are only set at only 2cm, but because of the smoothness of the spheres, they probably only arc over at 50kV or so.
Mon Aug 14 2006, 07:57PM
doh!
Looks like there is a reason that everyone builds marx'es with a lot of space between the stages...
Looks good otherwise tongue
McFluffin
Fri Aug 18 2006, 05:59AM
McFluffin Registered Member #119 Joined: Fri Feb 10 2006, 06:26AM
Look cool even if may need some work. Maybe you can dip it in laquer to stop the arching :) I was wondering, if you put a flouresent tube near this, does it light up like a coil would cause it to?
Wilson
Fri Aug 18 2006, 01:59PM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
i doubt whether it would, because a TC makes a sustained RF field, while this is just a single HVDC pulse discharge. Although I wonder what would happen if u hooked the outputs of the marx across a fluoro tube....
McFluffin
Sat Aug 19 2006, 07:16AM
BOOM! Thats what I'd think, but I really don't know a lot about Marx. I thought they pulsed rapidly like a TC does. Guess not. What are those brass ball things? They look nice.
I had an experience a while back where and LED exploded on me. Remembering that and then having a fairly large capacitor bank(~7kJ) I put the LED across it curoius what would happen, hit the button. It shorted out the LED and nothing happend(not even a flash). How dissapointing. So, what I am trying to say is, maybe nothing, but it would be worth a try.
williamn
Sat Aug 19 2006, 04:49PM
williamn Registered Member #55 Joined: Thu Feb 09 2006, 04:56AM
Have the marx dishcarge into a antenna.
Sat Aug 19 2006, 05:34PM
What size are those resistors? Im running low in carbon comp stuff, so it would be nice to learn of a new source of resistors that would take HV pulses.
I recently made an inductively charged marx generator using magnetos as the inductors (even with the core removed they are 4H). This generator worked great with 15" discharges from 280kV ideal output. I then began trying my own inductors. I tried a 2.5"diameter x 3" winding of 36awg, which provides about 12mH. This seemed to work fine for 3 stages, but dang thats a lot of work winding those things. I then tried 1.2mH, but it didnt perform as well. I think i found my best spark for the 3 stage test unit using inductors (1.2mH) was 4", but with high meg resistors it hit 7", mainly limited by surface tracking across my temporary setup. But, the inductor marx banks do have the unique feature that the output is oscillating at many khz, and i *did* get small streamers to form (that is, sparks, but without ground connection). I was hoping to get it up to 100+ shots a second, but spark gap quenching is turning out to be a real pain. I guess i will return to this next summer.
SpyrosF
Sat Aug 19 2006, 07:28PM
SpyrosF Registered Member #352 Joined: Tue Mar 28 2006, 08:39AM
are you looking for emp ?
GimpyJoe
Sun Aug 20 2006, 09:17PM
williamn wrote ...
Thus killing your computers, and the computers of all your neighbors... If you want to do this, definetly make a faraday cage.
Sun Aug 20 2006, 09:24PM
Considering I ran a DRSSTC meter away from open computer case and grounded to same mains 0 (no green wire) I think such and ''EMP'' is a hard way to go...
