Registered Member #117
I have access to IEEE Xplore. I searched for ball lightning yielded 45 results in IEEE publications. I also found this link on the IEEE website, unfortunatly the link on the page is broken, but apparently the speach did accually take place. Link!
Registered Member #96
Hi all. Recall that "spintronics" has been in the news recently as a way to reduce power dissipation in CPU's and memory.
Also recall that the basic idea is to align the normally random electron spins in a given material (usually iron/chromium nanowires or thin metal layers).
Perhaps ball lightning and other related phenomena might be generated in the lab by manipulating electron spins within a plasma such that the overall structure has an axial alignment in the direction of travel.
It appears that if this is indeed the case, on hitting a dielectric or metal the plasma will dissipate but the majority of the energy stored in the electron spins is transferred across the barrier, reappearing on the other side in a reduced but still active form.
An experiment to try might be to use an array of magnetised iron wires arranged in an x-y grid, so that the resulting corona has a spin alignment. If the discharge is intense enough the plasmoid should form and move off in the direction of least resistance (away from the wires).
Registered Member #10
Speaking to my physics prof the other day and he recalled an experiment in 50 Torr argon with indium sputtering. Aluminium was used to line the bell jar. They had a lot of problem with bright luminescent balls that would appear and char the aluminium black. It was a nuisance and never got documented or photographed properly but the nature was never explained.
Yep. I accidentally duplicated this annoying effect when trying to melt some indium alloy in my microwave. Sparks followd by a BIG bright blue-violet fireball that seemed stable for about half a second.
It might be worth using an indium electrode in an intense RF field to duplicate this effect, finally an experiment I can try :)
Alternatively, a pair of indium electrodes underwater?
edit:- Warren Buckles (Senior Technologist, American Superconductor Corp.), 1993, Madison, WI, USA. Email 2000. In 1993 I was testing a superconducting energy storage magnet in my company’s laboratory and accidentally discharged the unit into a metal oxide varistor. The resulting flash–bang was spectacular and yielded a ball of plasma-like material that persisted for several seconds while rising out of the apparatus. I recall the ball being about 300 mm in diameter and blue-white to yellow but such recollections under stress are unreliable. The magnet’s stored energy was about 1 MJ and the varistor had a nominal rating of 10 kJ and was manufactured by Harris in the US. The magnet’s circulating current at the time of the discharge was about 1 kA. As these varistors use a silicon oxide compound as their working element, I find your argument relating to filamentary chains of silicon oxides interesting. -A
