  • Guests: 16
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Asymmetric Tricopter Build (Half Step to Bicopter)
Fri Nov 02 2012, 11:38PM Print
1.) Current build... Version 2, Type 2, Mod 40, Build 3.
1351903601 2431 FT1630 Sam 0493layout
34 inches long, 29 wide...
Forward 2 props are APC slow-fly 10x4.8, CCW and CW.
Tail fan is MA, 7x6
Sat 10, 2012 Update:
1352608379 2431 FT146004 Airframe
This Vixen is looking real good!
1352610761 2431 FT1630 Seal2
Tail Art!
Fri Nov 02 2012, 11:50PM
2.) Previous Builds/lessons learned
1351905217 2431 FT1630 Sam 0475olod
tricopter (old) Flight proven...
wheighs 1.322kg, flies for 4-5 minutes on 3S (11.1V, 2200mAh).
Fri Nov 02 2012, 11:51PM
3.) Operation - Flight.
Fri Nov 02 2012, 11:53PM
4.) PID tuning and Sensory Aquisition....
5.) Supporting Souces and threads....
Sat Nov 03 2012, 01:19AM
6.) Current Build Components.
1352100750 2431 FT1630 Body
Airframe (S-2, CF-AS4, Epoxy and Balsa)
Using a space heater and hoping it cures right...
Ducts = 250g
airframe = 314g
motors = 156g
battery = 176g
electronics = 80g
mechanics = 140g
camera pan and tilit = 100g
lidar = 120g
total = 1336g
-1500g
=164g margin
Wens 14, 2012 HexTronic Motors:
DT 750's!
1352931307 2431 FT146004 Ht1
Long ass shaft to be cut down soon.
1352931307 2431 FT146004 Ht2
Standard super-mag seen here, much better than the soft mags on the E-Flites...
1352931307 2431 FT146004 Nt3
aluminum bell with stainless band.
Ive got motors!!!
Patrick wrote ...
Motor Mounts: work done as 11/17/2012
1353139491 2431 FT146004 Mm1
Templates, on 0.200" Bass wood.
1353139492 2431 FT146004 Mm2
Center relieved by 0.080" due to cheap chinese motors having an unpreditcable shaft length.
1353139492 2431 FT146004 Mm3
3 triganol planar screw pattern for 4-40 screws.
1353139672 2431 FT1630 Mm4
4-40 screws epoxied and ground flush.
1353139673 2431 FT1630 Mm5
Screws!
1353139673 2431 FT1630 Mm6
S-2 fiberglass coated to prevent splitting in crashes and to resist age and vibration weakness.
Mon Nov 05 2012, 07:46AM
Updated Build Pics...
Mon Nov 05 2012, 10:18PM
Can't you add one more gram to get it to 1337? smile
Tue Nov 06 2012, 02:19AM
Steve Conner wrote ...
what significance does 1337 have?
Mattski
Tue Nov 06 2012, 03:28AM
Patrick wrote ...
It's "Leet": LMGTFY
So what are the tradeoffs of a quadcopter versus a tricopter? If I'm understanding tri-copters appropriately from a quick googling, the two main fans provide lift and cancel each other's angular moments. Is the tail fan running continuously? It sounds like it tilts to provide yaw maneuvering. and I'm guessing it also provides pitch motion by varying its thrust. Do you worry about the angular moment of the tail fan?
