  • Guests: 21
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
BASIC Stamp 2, servo code... (My Training Wheels)
Thu Sept 13 2012, 01:02AM Print
ok trying to get simple code to repeat the PWM signal for standard servos.
im going to post some ideas here, so please tell me if i screw all this up...
I want to controlthe HS-55 HiTec servo, which can be seen here... Link2
I plan to send 600 to 2400 uS pulses every 20 mS or so, but i want a timer so i can choose the duration of the rotation (in the case of contiuosly rotating servos) I plan to use a rack linear gear too.
1347506083 2431 FT1630 Servo
Code, it seems to work, a noraml servo snaps to its commanded posistion.
NOTES:
--- 1494uS seems to be the center on the HS-55 modded for continuous rotation, it should be 1500uS, but if i tune it slightly i can see a deadband.
--- its datasheet claims a 8uS deadband.
--- As "..." said, 2.2k turned out to be close enough for a simple v divider.
--- its faster in one direction than the other, even given a full CW or full CCW command
I just wrote a simple infinte loop, but im still learning this embedded stuff so please comment.
1347516133 2431 FT1630 Textcode
EDIT: better code more functionality, extending and retracting a car antenna!
Sat Sept 15 2012, 05:02AM
Im thinking that a 1 amp H-bridge of SMT MOSfets, would solve many of my problems.
