  • Guests: 23
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
multistage coilgun trigger
josh1234
Tue Sept 11 2012, 07:12PM Print
josh1234 Registered Member #5969 Joined: Mon Jul 30 2012, 09:27PM
i have built a few single stage coilguns in the past but there efficiency was only about 0.2% so i want to build a multistage coil gun with about three stages
i am going to use igbt's to trigger the stages so i can turn them off when i want
would this idea work
as shown in the picture below
as the projectile blocks the infa red led and detector (blue) it triggers the coil but when the projectile is fully inside the coil (orange) and the ir detector detects ir again it terns the coil off
or is there a better way like it detects the projectile and you set the delay on when to switch it off
1347390657 5969 FT0 Coilgun Ir Trigger
PSCG
Wed Sept 12 2012, 08:20AM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
You could start by looking at this link. Another Coilgun also has good information about triggering (click on the "Projectile Detection" link) that can be scaled for as many stages as required.
The usual approach for triggering MOSFETs or IGBTs is a 555 configured as a one - shot oscillator (so that it only gives one pulse for triggering) and a second one as a delay (where you can adjust the time delay between the initial trigger pulse and the actual output). Although all these can be very easily duplicated inside a microcontroller.
Keep in mind that triggering MOSFETs or IGBTs is a bit more difficult than triggering SCRs because of the fact that after you switch them ON you must also switch them OFF. That means a circuit that must either have a fixed trigger pulse length or it can track the projectile's position relative to the accelerating coil. SCRs only need to be switched ON to operate (and will be kept ON until the voltage between the cathode and the anode drops below a certain limit or reversed).
Saz43
Fri Sept 14 2012, 02:44AM
Josh what you posted will work just fine and is in fact the preferred method for triggering a coil with IGBTs. The method PSCG described will also work, but it's what you call "open loop" since it requires user input to guess the timing, whereas your method is "closed loop" meaning it knows exactly when to start and stop the pulse every time without user input since it can sense the projectiles position. It's more accurate and simpler to implement. It's the same method I've used very successfully in my 8 stage IGBT coilgun.
josh1234
Fri Sept 14 2012, 04:17PM
what is the best position for the projectile to be in when the coil is triggered
Sat Sept 15 2012, 01:13AM
josh1234 wrote ...
You'll have to build it and run a series of trials to see what works best for you.
In all likelihood, the best position will be pretty near where the front of the projectile is flush with the coil entry.
Cheers, Barry
Time flies when you're having rum.
josh1234
Sat Sept 15 2012, 08:12AM
so my idea might work quite well
when the projectile tip just enters the coil it turns on and when its in the middle it switches off
