  • Guests: 22
GODSFUSION (37)
Zajcek (37)
ElectroDog (33)
sportcoupe (56)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
capacitors
phil
Wed Aug 09 2006, 08:39PM Print
phil Registered Member #314 Joined: Mon Mar 13 2006, 03:12AM
Hi guys, it's been a while since i last posted. My summer has basicly consisted of work, and then comeing home to work on some robotics projects for the FIRST competition next year. But i recently salvaged an old PC power supply from one of my computers (RIP server # 4) and i noticed that there are 2 200V 470uF capacitors and some transformers in there. I was originally going to turn it into a lab power supply but before i do i wanted to ask you guys. would those capacitors be good for a Coil launcher? I'm still quite a novice with electromagnetic particle accelerators so please forgive me if that was a stupid question.
Bjørn
Wed Aug 09 2006, 08:54PM
They are good for making a first coil gun and for learning. You have about 20 J of energy and you can at most expect to have 10% efficiency, then you can figure out how fast your projectile will move with an optimal design.
phil
Wed Aug 09 2006, 08:57PM
Thank you, guess i'll have to buy a lap supply after all cheesey
Wilson
Thu Aug 10 2006, 02:47AM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
You can also find similar caps in practically all common electronics, eg TVs, laser printers, monitors, etc.
phil
Thu Aug 10 2006, 03:05AM
Hmmm, i think i have an old CRT lying in the basement, i should give that a try.
Electroholic
Thu Aug 10 2006, 08:09AM
yea you should be able to find 1 or 2 lytics, around 220uf to 330uf at 400v
phil
Fri Aug 11 2006, 02:53AM
I also noticed a few transistor looking things. Is there a way of telling whether their a SCR?
Fri Aug 11 2006, 03:01AM
The transistor looking things are transistors (98% sure) To tell what a given part is, type the numbers into the search box at alldatasheet.com and see what turns up.
If you need some scr's I would be happy to send you a few (free in us, or $5 global) pm me.
Thu Sept 28 2006, 01:16AM
For a heavy duty coil gun where does one get a robust enough SCR? I have a 50A rms/600A peak SCR ( 511-BTW69-1200 ) from Mouser. What if I wanted a peak surge of over 1000A or more?
Electroholic
Thu Sept 28 2006, 01:39AM
ebay?
I have a 50a stud with 1.5ka pulse rating.
its a 50ria120 or something like that.
i believe yours will do fine for a short pulse at 1ka.
I also got a few SKKT132/16Es 4.7ka pulse off ebay.
