  • Guests: 56
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
PIC help please
Part Scavenger
Mon Aug 07 2006, 01:11AM Print
I'm trying to multiplex stuff by using the Timer2 on the PIC16F684. However, it doesn't ever seem to interrupt. I'm trying to run a two strings of LED's alternatively with alternating displays. I think the code is pretty self-explainatory.
I've double-checked all of the information I can find on interrupts/TMR2, etc, and my settings appear correct.
What did I do wrong in my code?
list p=16F684 ; list directive to define processor
#include <p16F684.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
__CONFIG _CP_OFF & _CPD_OFF & _BOD_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _FCMEN_OFF & _IESO_OFF
;***** VARIABLE DEFINITIONS (examples)
; example of using Shared Uninitialized Data Section
INT_VAR UDATA_SHR 0x71
w_temp RES 1 ; variable used for context saving
status_temp RES 1 ; variable used for context saving
LEDPORT equ PORTC
LEDPORT2 equ PORTA
DRV1 equ 0
RESET_VECTOR CODE 0x000 ; processor reset vector
goto main ; go to beginning of program
cblock 0x20
count1
counta
countb
ones
tens
end c
INT_VECTOR CODE 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
btfss PIR1,TMR2IF ; Flag set if TMR2 interrupt
goto INTX ; Jump if not timed out
; Timer (TMR2) timeout every 16 milliseconds
bcf PIR1,TMR2IF ; Clear the calling flag
; isr code can go here or be located as a call subroutine elsewhere
btfss LEDPORT2, DRV1
call do_tens
call do_ones
INTX movf status_temp,W ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,F
swapf w_temp,W ; restore pre-isr W register contents
retfie ; return from interrupt
main
; remaining code goes here
movlw 07h ;turn off the comparators
movwf CMCON0
movwf CMCON1
bsf STAT US, RP0 ;setup ports as all outputs
movlw 0x00
movfw TRISA
movfw TRISC
bc f STATUS, RP0
; Set up Timer 2.
movlw b'01111110' ; Post scale /16, pre scale /16, TMR2 ON
;movlw b'00010110' ; Post scale /4, pre scale /16, TMR2 ON
movwf T2CON
bsf STATUS, RP0 ;select bank 1
movlw .249 ; Set up comparator
movwf PR2
bsf PIE1,TMR2IE ; Enable TMR2 interrupt
bcf STATUS, RP0 ;select bank 0
; Global interrupt enable
bsf INTCON,PEIE ; Enable all peripheral interrupts
bsf INTCON,GIE ; Global interrupt enable
Loop
movlw 0x00
movwf ones
movlw 0x00
m ovwf tens
call Delay
movlw b'000001'
movwf ones
movlw b'100001'
movfw tens
call Delay
movlw b'000010'
movwf ones
movlw b'010010'
movfw tens
call Delay
movlw b'000100'
movwf ones
movlw b'001100'
movfw tens
call Delay
movlw b'001000'
movwf ones
movlw b'010010'
movfw tens
call Delay
movlw b'010000'
movwf ones
movlw b'100001'
movfw tens
call Delay
movlw b'100000'
movwf ones
movlw b'000000'
movfw tens
call Delay
goto Loop
do_tens
bsf LEDPORT2, DRV1
movfw tens
movwf LEDPORT
retlw 0x00
do_on es
bcf LEDPORT2, DRV1
movfw ones
movwf LEDPORT
retlw 0x00
Delay
movlw d'250' ;delay 250 ms (4 MHz clock)
movwf count1
d1 movlw 0xC7
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
end
BTW, if you can't tell already, I'm new at this so it's likely to be something stupid.
Thanks
Mon Aug 07 2006, 09:53AM
The PIE1 register is in memory bank 1, so you have to use the bank select bits to access it. (and remember to put them back afterwards.) You didn't use them, so it never gets written and your interrupt stays disabled. I like to use the banksel macro:
banksel PIE1
banksel 0
The banked architecture is one of the PIC's pains in the ass. You have to remember which registers can't be accessed from bank 0. It still catches me out after programming PICs in assembler for about 7 years.
Part Scavenger
Mon Aug 07 2006, 10:05AM
Thanks! I'll try that.
I also noticed I've got code inbetween the interrupt and main code, and that it's skipped over. angry
Thanks
Bjørn
Mon Aug 07 2006, 01:49PM
The banks alone is a reason to not use a PIC. Not all PICs have the registers in the same banks so it is almost impossible to get it right all the time.
The banksel method that Steve uses is the best method to make readable code that will work on different PIC models.
Don't use interrupts unless there is a reason to because they are an extra source of problems. Both timing and your simple mental model of the PIC goes out the window when you use interrupts.
Use interrupts when you need to save power or minimise response time.
Part Scavenger
Fri Sept 22 2006, 02:25PM
If anyone is interested, my biggest problem was that I was using the "template file" from MPLAB, and it's interrupt variables were overlapping my own variables. angry
