Lens/ccd technology is well developed, fairly cheap and instant.
The CCD would be there ofcourse. The raw information from the CCD would go straight to the algorithm. The algorithm will mimic the "focusing" which was earlier done by a lens.
So in summary normal setup; just without the lens. the lens being replaced by the algorithm.
Registered Member #72
So why can't you deconvolve the blur of a big pinhole?
1) knowing blurring function to sufficient accuracy 2) signal to noise ratio of the sensor 3) the sensor reads intensity, not signed amplitude
And the most important of these is 3. Although in any deconvolution exercise, noise enahncement due to zeros or small numbers in the deconvolution function, and inaccuracy of the estimate, can damage the result, that's all moot because of number 3.
The image sensor can't capture negative amplitudes. It reads only intensity. If you set a function up in MATLAB or Python/Scipy, blur it by convolving with the Fresnel function for a big pin hole, you'll see that some of the resulting amplitudes will be negative. However the imaging medium, whether film or CCD, will measure the absolute value. Having rectified the image, it is now impossible to deconvolve it to what it was. You might do a job of cleaning it up a bit, but in taking the absolute value, enough information is gone forever.
If you tried something like iterative backprojection, ie what scene could have caused this image, then you are still left with a massively underdetermined problem which can only admit to very approximate solutions.
Now, if you were recording a hologram, and beating the recording with a laser, you could reconstruct the original image, because the sign as well as magnitude is encoded.
Registered Member #2901
Dr. Slack wrote ... Now, if you were recording a hologram, and beating the recording with a laser, you could reconstruct the original image, because the sign as well as magnitude is encoded.
Actually generally they don't record both (that's why off axis holography is generally used, lets you separate the error from the original signal on replay).
Thanks for the responses guys, very interesting stuff. I guess the same applies for trying to mimic a zoom lens.
Though on a slightly different tangent I recall a concept camera developed by canon having a ridiculous level of zoom (Maybe they used a massive sensor with over sampling). I wonder what they did
Steve Conner wrote ...
The Lytro light field camera claims to allow you to refocus its pictures after they are taken. Not sure how well it works in practice.
The lytro uses a wholly new concept altogether, there are some examples on their website, it does work well, but im not aware of any real use for it besides the novelty aspect.
This article in New Scientist this week suggests another way of improving the image, subtracting the intensity of two images, where there's a known difference in scene between the two.
They do say that, even enhanced by the technique, it's only an improvement, it's still not as good as a real pinhole
Registered Member #1667
forgive me for not verifying it has already been pointed out here somewhere:
coded aperture lens systems avoid the blind deconvolution problem and allow a crude depth map reconstruction of a single 2d image. I recently found something interesting about the algorithmic improvements of full-res reconstructions of light field images. Coded aperture pictures tend to suffer from strange artifacts.
