  • Guests: 20
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
My computer keeps crashing!!!!
Luceš
Sat Jun 09 2012, 02:26AM Print
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
I have my computer dual booted debian and windows xp. It is a 3ghz dual core 64bit dell. My brother has been useing it alot latly and all of the sudded it crashes, and its getting worse, first i thought it was a virus but it is doing both on xp and linux!!
PLEASE HELP!!
Sat Jun 09 2012, 05:51AM
I would;
-clean the internals - especially the cpu fan/heatsink which gets clogged up quite easily on some Dell computers as they use very fine fins for better cooling.
- if that's not the problem run a memory diagnostic.
- worst case buy a new HDD (can be used as a second HDD later for media etc)
and do a simple single OS install and see how that goes.
Dr. Slack
Sat Jun 09 2012, 07:18AM
Take a look at the 'lytics in the CPU power switcher area, and see if any of the tops are bulging. They are notorious for going bad, and the resulting power supply errors cause anything from corrupted data to random crashes. A MoBo is about the same price as a HDD. My PC passed the Prime95 torture test but still randomly crashed, until I noticed those distended caps and changed the MoBo.
Sat Jun 09 2012, 12:17PM
Or replace them, see Link2
I have saved a few boards this way, usually if the board still boots at all then changing them will fix it.
-A
Luceš
Sat Jun 09 2012, 03:25PM
Thanks for the response guys, I would go get a can of air. And if that not work I would try more drastic things.
Thanks!
Luceš
Tue Jun 12 2012, 03:09AM
WWWWWWWWWWEEEEEEEEEEEEEEEEEEEEEEEEELLLLLLLLLLLLLLL LLLLL, good news everyone... this is embaresing. MY VIDEO CARD WAS LOOSE AND CAUSING IT TO CRASH!!! amazed Im so glad is wasn't expensive to fix!
