Registered Member #3806
Hello,
I bought on Ebay some Sprague 650pF 18kV capacitors.
Now I'm trying to find suitable bolts or threaded rod
The metric 4x0.7mm bolts almost fit in, but I can screw only one turn, then it blocks because the thread pitch is different.
I found a french online shop selling all US sizes bolts, but I don't know how the US system works for bolts... I'd be glad if someone knowing these capacitors could tell me what is the correct US size for these bolts.
Thanks Steve for your answer,
in 8-32, is 32 the number of threads per inch ? and what means 8 ?
(still trying to figure out how th US system works... lol)
EDIT :
I found a bolt that perfectly fits in the capacitors. It's diameter is 4.15mm and thread spacing is very close to 0.8mm, which gives 32 threads per inch.
Registered Member #2099
Good work!
In case you didn't notice, the US number-size thread standards (unlike number-size drills and wires ) have equally spaced basic diameters. That makes the diameters easy to construct from memory, with or without the formula d = 0.060 + 0.013 * N.
The reference you pointed to does not indicate the relative popularity of the small inch threads. Only rarely do designers (when restricted to inch-size preferred parts lists) depart from: #0 0.060 -80 #2 0.086 -56 #4 0.112 -40 #6 0.138 -32 #8 0.164 -32 #10 0.190 -24 (UNC) and -32 (UNF) 1/4 -20 (UNC) and -28 (UNF). Except Harley-Davidson motorcycle company uses 1/4-24. And inch micrometers use 1/4-40.
When it comes to screw-cutting lathes, the gears for N threads per inch are no more complicated than those for N/10 millimeters per thread. One amusing standard used in billions of parts is the US garden-hose thread: Basic OD = 1 + 1/16 inches, threads per inch = 11 + 1/2.
Review question: How many threads are on a 12-inch length of 8-32 all-thread rod? Answer: One.
Registered Member #3414
As an aside, if you have an old imperial screw cutting lathe with change wheels, and you have a change wheel with 127 teeth, you can cut metric threads on an imperial lathe (127/5=25.4, so you can cut 25.4 threads per inch, and multiples thereof, etc.).
@klugesmith: very interesting explanation, thanks for it What bothers me is that some sizes are designated by their number, while others are identified by their size in fractions of inches, but I'll get used to it.
@Ash Small: I don't have this material, but it's good to know the trick
I found them on Ebay, they look nice :) I'll just have to cut a few mm, they're a bit too long for these capacitors.
PhilGood wrote ... ... I found them on Ebay, they look nice :) I'll just have to cut a few mm, they're a bit too long for these capacitors.
Nice bag of screws you got there, Phil. For making them shorter, are you familiar with the screw-cutter feature of many wire strippers and connector crimpers?
You open the pliers until the threaded holes line up with unthreaded clearance holes on the other side. Screw in the screw as far as you like. When you close the pliers, it shears the screw (crushing some threads on the far section). The sheared end of the near section gets cleaned up when you unscrew the shortened part.
I would be surprised if there aren't similar tools for cutting metric screws.
Oh, about the sizes chosen by U.S. designers, and stocked in hardware stores. Below 1/4 inch it's almost always even-numbered sizes. #10 is practically the same as 3/16", and #12 is uncommon. For 1/4 inch and larger screws, we use the familiar binary fractions: 1/4, 5/16, 3/8, 1/2, 5/8, 3/4, 1 inch.
My middle employer (of 3 U.S. start-ups and IPO's) adopted a preferred-metric policy in the beginning. The mechanical engineers and purchasing staff got used to it. I didn't hear of any problems.
I remember this feature on older crimpers and strippers like the one you posted.
But I never used it earlier, and it's a good thing you mentioned it, because I just forgot it. I'll get one of these pliers ! (Or even two: one metric and one imperial)
I usually use a Dremel with a cutting disk to cut screws, the result is perfect and it does not damage the threads, but it is more complicated.
It's funny and quite uncommon to see an US company using the metric system, but hey, why not
