  • Guests: 25
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
First Proper Coilgun
Mon May 21 2012, 09:10AM
i assume its
1 2 3
*extreame embaressment moment*
Legit_bacon
Mon May 21 2012, 10:38AM
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
One would assume, apparently google doesn't know but I don't think this part would be any different in its numbering than every other part like it on the planet.
Mon May 21 2012, 11:07AM
heh, ok, il give it another go when i get home tonight, i belw up one of them using what google said!!! cry
Mon May 21 2012, 01:34PM
The pin numbers are shown on the second-last page of the SCR datasheet that you linked.
Hand in your geekpoints at the door on the way out. tongue
Mon May 21 2012, 03:57PM
awwrrr, stop being so mean to me, *pulls out wallet and hands geekpoints to you*
time to do Science! *scurrys off to lab*
Wed Jun 13 2012, 08:33PM
Tom Williamson wrote ...
im sorry, i didnt make myself clear >.<, i cant work out the pin numberings, ive got 50 different sites telling me different numbers and the datasheet isnt exactly clear x.x
Make an SCR test jig. Use a car battery or 12v supply (instead of capacitor) and a 60w light bulb (instead of coil). I've had a lot of trouble identifying terminals or even knowing if the dumb SCR is working or not. Believe me, this can save you a lot of time and frustration.
Cheers, Barry
Platinum
Sat Jul 28 2012, 06:37PM
I made a awful coilgun 450v @ 1500uF, anyway I used a relatively small SCR, I checked the datasheet, looked to see what the gate voltage was and then I just used a small switch and a AAA battery to trigger it, worked perfect.
Harry
Sat Jul 28 2012, 06:54PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
I tried to trigger an SCR with an ATX PSU once, but forgot that the supply ground is connected to mains ground, and the charging system was rectified mains. Needless to say, the GFI went instantly. cheesey
