  • Guests: 27
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
First Proper Coilgun
Tue May 08 2012, 05:21PM Print
Hi folks,
ive got these for the diode:
and these for the SCR:
my capacitors are 2x 400v 4700uf
are they all sutable to work together and how do i calculate the resistence for the SCR trigger, should i use a PP3 battery
thanks,
Thomas Williamson
Inducktion
Tue May 08 2012, 06:08PM
In the datasheet is a value for gate turn on current... I believe it's 100 mA?
Just look under the "triggering" bit of the datasheet.
Tue May 08 2012, 06:27PM
yes, but how should i calculate the resistor value so i dont burn it out on 9v?
apparently it should be 75Ohms
R = (V - Vg) / Ig ?
Forty
Tue May 08 2012, 11:50PM
Ha! I use those same SCRs and I've mentioned them on here about a dozen times. Mentioned those diodes a couple times but I haven't used them yet myself (my free sample allowance from vishay seems to have expired.) Glad to see someone else trying them both out.
That's exactly how I'd calculate the gate resistor value, so I agree with the 75 ohms.
You're going to need a fairly large coil to get the peak current from even one of those caps down into the range that the scr can handle.
I've had success paralleling the 70tps12. Two ~1.5" lengths of ~1/8" thick by ~5/8" wide bars of copper were slotted across the thickness, near the end, spaced according to the distance between successive scr pins when they're butted together (front to back). The legs of three of the scr's were cut off near the base where they come out. The scr's were zip tied together and the stubs of the anode and cathode were soldered into the slots on the copper bars, with the excess length of the copper protruding from opposite sides. The protruding bit was then drilled so that heavy ring connectors could be bolted on. The gates each had their own resistor to balance out the current, with the other ends of the resistors all being tied together. I suppose a picture would show all of that at once, but I don't have a camera. A better explanation or a picture could probably be given if you're interested.
I've also found (possibly because of how the back emf/quenching works) that these scr's will fail if they are used at the positive side of the capacitor-coil circuit, so put them on the negative/ground side.
Tetris
Wed May 09 2012, 03:03PM
What are the specs on it? :D
Sun May 20 2012, 09:21PM
how do you wire one of these SCRs, i tried and blew it, probibly got the wrong pins
im a total noob :(
Pinkamena
Sun May 20 2012, 11:02PM
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
Just follow the data sheet. Check out wikipedias article on them if you want to know how they work. If I'm not mistaken, the anode connects to positive, cathode to ground. When you apply a voltage to the gate, it will turn on. For example like this:
ISafY
Saz43
Mon May 21 2012, 01:15AM
Tom Williamson wrote ...
im a total noob :(
I made a whole guide to designing SCR coilguns, I've been meaning to put it on a website but I just can't think of a name. Till then, I hope this will help:
Th SCRcoilgundiagram
Oh and please ignore the equation for the resistor, the one posted previously is correct.
Mon May 21 2012, 05:36AM
im sorry, i didnt make myself clear >.<, i cant work out the pin numberings, ive got 50 different sites telling me different numbers and the datasheet isnt exactly clear x.x
m4ge123
Mon May 21 2012, 08:16AM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
The datasheet is perfectly clear... 1 is the cathode (K), 2 is the anode (A), and 3 is the gate (G).
