  • Guests: 71
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
Help With Interrupts in AVR C
Daniel Kramnik
Sun Apr 08 2012, 10:00PM Print
Daniel Kramnik Registered Member #3885 Joined: Sun May 15 2011, 12:47AM
Hi all!
I'm just getting started with AVR C and I'm having trouble setting up an interrupt on my ATTiny85V.
I have LEDs connected to Port B bits 1 - 4 and a pushbutton to ground connected to Port B bit 0. With this code, I am able to detect the state of the button (if it is currently being pushed or not), but the ISR is not called (I set an interrupt on PCINT0, and I only enabled source 0, so my pushbutton should trigger the ISR).
Any help at all would be appreciated! Normally, the code just fades the LEDs back and forth.
UPDATE: a friend pointed out that _SEI() isn't being called where it is in this code, so global interrupts are not being enabled, but when I move it into main or setupInterrupts, I get an undefined reference error - any suggestions?
FIXED!
It needs to be sei(), not _SEI()
hope this helps someone else who's having trouble!
#include <avr/io.h>
#define F_CPU 800000UL
#include <util/delay.h>
#include <avr/interrupt.h>
_SEI(); //Enable Global Interrupts
#define TRUE 1
#define FALSE 0
typedef int boolean;
#define topLEDLocation 0b00010000
#define bottomLEDLocation 0b00000010
#define pullUp 0b00000001
void blink();
void updateDelay();
void _delay_xus(int us);
void setNextByte();
void setupInterrupts();
int delayTime = 0;
boolean cylonUp = TRUE;
volatile boolean interruptFlag = FALSE;
unsigned char leadingByte = 0b00000100;
int main(void)
//Set all pins as outputs
DDRB = 0xff;
//Enable response to interrupts
setupInterrupts();
//Set all outputs low, enables internal pull-up on input pin 0
PORTB = 0x01;
//Main program cycle
while(1)
//This tells us if an interrupt has been detected - use for debugging
if(interruptFlag)
PORTB = 0xff;
_delay_ms(100);
PORTB = 0x01;
_delay_ms(100);
PORTB = 0xff;
_delay_ms(100);
PORTB = 0x01;
_delay_ms(100);
PORTB = 0xff;
_delay_ms(100);
PORTB = 0x01;
_delay_ms(100);
if(PINB & (1 << 0) == 1)
//Makes the LEDs glow dimly if the button has not been pressed - use for debugging
PORTB = 0xff;
blink();
updateDelay();
return(0);
void blink()
//Start the first LED with low pulsewidth
PORTB = pullUp | leadingByte;
_delay_xus(delayTime);
///Start the second LED with high pulsewidth
if(cylonUp) {PORTB = pullUp | leadingByte >> 1;}
else {PORTB = pullUp | leadingByte << 1;}
_delay_xus(1000 - delayTime);
void updateDelay()
//Goes to the next set of LEDs once the leading LED has reached maximum pulsewidth
if(delayTime == 1000)
setNextByte();
delayTime = 0;
//If the leading LED has not reached maximum pulsewidth, increase the pulsewidth
else
delayTime += 10;
//This methods lets us use a variable with the _delay_us method instead of a constant
while (us--)
_delay_us(1);
//Determines which LED to jump to next
void setNextByte()
if(cylonUp)
if(leadingByte == topLEDLocation)
leadingByte = leadingByte >> 1;
cylonUp = FALSE;
else
leadingByte = leadingByte << 1;
else
if(leadingByte == bottomLEDLocation)
cylonUp = TRUE;
else
//Sets the interrupt pin as an input
DDRB &= ~(1 << 0);
//Enable pin change interrupt
GIMSK |= (1 << PCIE);
//Enables PCINT0, leaves all others disabled
PCMSK |= (1 << PCINT0);
ISR(PCINT0_vect)
interruptFlag = TRUE;
