  • Guests: 47
CSU Chico Tilt Rotor Flying Machine, (Programming and CPU, 3 of 3).
first  3 4 5 6
Wed Nov 07 2012, 09:32PM
its not transmitting /recieving thats the problem, i think its complicated programmimg, missing real time slots of needed data.
Pinky's Brain
Fri Nov 09 2012, 08:54AM
Patrick wrote ...
the N wireless router were used, its complicated settings and code that are cuasing the failures not the transmitting/recieving router itself...
in august 2012 it seemed the routers stayed up and running almost constantly, but the machines/desktops just wouldnt syncronize for useful data. the machines that were flying often hovered, then with a 3 second delay flew themselves into walls then, while crashed in pieces on the floor, it then tried to execute a collision avoiding turn.
With all due respect, if you can't do a simple remote procedure call over a reliable wireless connection of negligible latency and relatively high bandwidth you're doing it wrong. It's only complicated if you work hard at making it complicated.
That said, how are you so sure the connection was reliable? WLAN is prone to interference because it's such a polite protocol and sticks to a single channel, the delay could just as easily be from exponential back off and if they are stupid enough to use TCP that would only make it worse.
A nRF24L01+ based link might be more reliable.
Carbon_Rod
Fri Nov 09 2012, 09:52AM
"Tunnels TCP over UDP packets. Runs in user space on Linux, Solaris, Cygwin (with IPv6 extension), and native Win32."
This method maintains a data stream over a stateless protocol:
The other tips discussed will mean rapid recovery from signal collisions, corruption, and throttling.
Fri Nov 09 2012, 10:11AM
There's no such thing as a simple remote procedure call. Distributed computing is always going to be tricky, and real-time deadlines only make things trickier.
I say this having written my own RPC library that can do 10,000 RPCs per second. smile
Pinky's Brain
Fri Nov 09 2012, 02:33PM
Most of those problems come into existence when you don't treat the connection (and the remote party) as 100% reliable ... if as Patrick maintains they are that simplifies everything.
Although as I indicated, I kinda doubt the connection is that good.
Fri Nov 09 2012, 03:11PM
That's exactly the issue with distributed computing. When you call a regular function, you know it's going to execute and return a value. But when you do a remote procedure call, it could fail. Either it times out, or hangs forever, or if you decided to be very clever and do non-blocking transactions, your program already carried on without knowing if the RPC failed.
If you try to handle this gracefully, you get screwed by the complexity. If you ignore the issue and pretend that remote procedure calls will never fail, you get screwed when one eventually does fail.
I dealt with the issue by using a very simple RPC protocol and making sure the underlying hardware bus really was reliable. Patrick may need some other approach. I would have the drone default to hovering motionless, sending sensor data back to the desktop machine, until the desktop commanded it to make a move, along the lines of "Go 10 yards northeast and wait for my next command".
The drone could have a very basic collision detect algorithm on board to stop it from smashing directly into walls if given bad commands. It's easy to stop the commands getting corrupted in transit by just adding a CRC. But it's much harder to stop the desktop software from interpreting the sensor data wrongly and commanding the vehicle to fly into a wall that it didn't realise was there, so I would want a second opinion from a simple algorithm that has access to fast, accurate real-time data. Not "wall 10 yards away" but "wall real close right now!"
For extra brownie points, you could hook the desktop software up to a simulated vehicle in a virtual maze and test it without trashing anything, except a lot of 1s and 0s, but those are pretty cheap. smile
What does the AR Drone do when it loses its wi-fi connection?
Fri Nov 09 2012, 06:12PM
Steve Conner wrote ...
the Indian university teams found, if they unplug the wifi router, there Ar just hovers indefinatley, they had to activly transmit a fail-safe turn off command, so they were disqualified and prevented from flying at all in 2012.
Fri Nov 09 2012, 07:00PM
Is that a safety rule, that it has to shut down if it loses signal?
Fri Nov 09 2012, 08:58PM
in the past its been complicated though.
yes there must be a positive safety fail... the absence of a "keep alive" signal must cuase shutdown.
They used to have nitro/alchol 700 size helis, a common kill mechanism was to have a servo pinch the fuel tube shut. however when one team did this back in 93ish, the engine ran lean off the float carb remanants producing more power, then it flew out of control closely past the epcot dome continued above the parking lot and crashed in front of a bunch of African school children. no one was injured, but after that they really have been on us about safety.
Pinky's Brain
Fri Nov 09 2012, 08:59PM
Patrick wrote ...
EDIT/UPDATE: found this for 55 USD, 25 Grams!!! Link2 i just dont know how to interface to it !?
The processor is nice, but with no GPIO breakout it's kinda limited ... the amount of GPIO broken out on Raspberry PI is sadly pathetic too.
The Cubieboard is shaping up to be the best platform for A10 hacking :
Dunno when it's shipping again though. In the meantime the Beaglebone is one of the nicest development boards with a relatively powerful processor, only 36 grams too.
first  3 4 5 6
