  • Guests: 12
  • Members: 1
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
CSU Chico Tilt Rotor Flying Machine, (Programming and CPU, 3 of 3).
AndrewM
Wed Jul 11 2012, 01:17AM
In controls (maybe just aeronautics?) "dot" is the same as prime which is the same as derivative.
So theta_dot = d theta/dt (angular velocity)
theta_dotdot = d2 theta/ dt2 (angular acceleration)
Wed Jul 11 2012, 01:44AM
AndrewM wrote ...
whoops! i see what you meant, yes i knew that, brain lapse... im not good at ASCII math anyway. do you know anything about programming in C?
ok so theta dot= (d theta )/( dt) which effectivley means: (change in angle theta) / (change in time)
therefore if the time interval is consecutive and constant: (d theta)/(dt) = (current theta - previous theta)/(time interval)
and i think thats what Brett Beaureguard means in this line :
[ double dErr = (error - lastErr) / timeChange; ]
AndrewM
Wed Jul 11 2012, 04:22AM
I've never been very good at reading other people's code, I usually just write my own... so I didn't read that page.
But yeah, looks like numerical differentiation to me.
Wed Jul 11 2012, 05:10AM
well you and i are going to get this working so well need to figure out rolling, pitch collective and yaw and pid's and every other little thing we need, i want this done in less than one year from now.
I really appreciate your help, im going to stay on this everyday.
Carbon_Rod
Wed Jul 11 2012, 08:53AM
Typically for UAV aerial acrobatics, people use Minimum Jerk Trajectory planning with Visual Servoing.
If you start to run out of time, openservo is a cheap mod that will reduce some of the errors that you are about to encounter...
Note that most gyros & some accelerometers will have oversampling error reduction, and low pass filter options...
i.e. simply use the on chip noise filters if you know the craft will not exceed a few g or high angular rates.
@AndrewM There are few robust alternatives outside the consensus of prior threads...
... the current approach will unlikely stay in tune very long... wink
Note a 200gram 1GHz wifi enabled mini computer is $68 delivered....
And it runs a popular distro:
Wed Jul 11 2012, 02:26PM
Carbon_Rod wrote ...
i will use the onboard low pass filter that my chips already supportand i still need to worry about gyro drift, but as for your 68$ computer thats not a real embedded system, and i cant configure pins on it or a RTOS like i can with a pic, ardiuno, STAMP or STM32.
edit, super dooper important:
]filter.pdf[/file]
Carbon_Rod
Thu Jul 12 2012, 05:04AM
In general, latency tolerant functions are located within an RTlinux kernel based OS with usb host stack and wifi.
Most RTOSs are not what the name implies, as the last real RTOS was MSDOS.
In general, people who believe otherwise are better off using multiple chips/boards....
A 12Mbps USB host link will add little latency to consumer sensors given maximum sample rates will rarely exceed 400Hz...
Note a 1.5GHz Cortex-A8 A10 with 1GB ram and a cheap interface chip for i/o is flexible... wink
Thu Jul 12 2012, 05:50AM
I dispute your claims, yet that clip was funny.
Carbon_Rod
Thu Jul 12 2012, 08:40AM
Specifically, schedulers need to save multiple machine states for threading/message-passing, interrupts may overlap ISRs to randomize stack-pointer/register save times, and multi-core/GPU systems have several types of resource contention.
Most multitasking RTOS are approximating a fixed latency scheduler even if written in Assembly. If the accumulated errors from timing jitter are negligible/profiled than people sell it as an "RTOS".
"dispute" infers there is some inherent value in deception requiring negotiation... tongue
Thu Jul 12 2012, 12:11PM
dispute the meaning of dispute all you want cheesey Ill stick with my STM32's for the time being since they handle GPIO, I2C and SPI nativley, and a traditional computer doesnt.
