  • Guests: 24
Shaun (34)
Spedy (30)
05/01 Shaun (34)
05/01 Spedy (30)
05/02 Adam Munich (30)
Feedthrough Capacitors
EDY19
Wed Jul 26 2006, 03:52AM Print
I have 3 of these mallory capacitors, in their boxes, rated at 1000mmfd (1000pf) at 600VDC, however, they have three different part numbers on their boxes, CT-280A, CT250A, and CT-254A. Are these anything special, or do they have any good uses besides timing circuits tongue ? They are a ceramic looking cylinder about .2" in diameter, with two wire loop terminals on opposite ends, with a total length of about .7".
robert
Wed Jul 26 2006, 12:04PM
robert Registered Member #188 Joined: Thu Feb 16 2006, 05:18PM
These caps usually are used for feeding power supplies into a shielded enclosure (as in RF transmitter or reciever ciricuts that porudce interference/are sensitive to it) while keeping it shielded eg no hole in the shielding.
The construction of these is optimized for low inductance but dont expect them to be suitable for anything beyond their intended use.
