  • Guests: 26
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Coilgun
Platinum
Fri Nov 18 2011, 02:18PM Print
Could I make a coilgun out of 2 400v 330uF caps?
Could I, They are electrolytic.
I'm also not sure about winding the coil, do I use alot of turns of thin wire, and not so much with thick wire, I'd appreciate help :)
Inducktion
Fri Nov 18 2011, 05:20PM
Sure! It'll be a relatively small coilgun, and if it's your first, then that would probably be a good thing.
to wind a coil, you'll need relatively thick wire. I used 14 gauge, 12 gauge, 16 gauge wire would also work. Enameled wire is the best to use as the insulation adds unnecessary air gap between the coil and the projectile.
Find some smallish PVC pipe, around the size you want your projectile to be. Then just wind away!
Turkey9
Fri Nov 18 2011, 06:02PM
At around 50J, I'd use whatever wire you have on hand. It doesn't need to handle thousands of amps so anything larger than say 22AWG should be fine. Also, pen tube things (the main body of ball point pens) work great for the barrel of a first coilgun. Thin walled and cheap (usually free!).
Platinum
Fri Nov 18 2011, 06:46PM
I'm using some wire I got from a large fan, I've used all of it, there's alot of turns, but I didn't keep count.
And it I found a copper pipe to use as a barrel, it's 0.45" inside diameter. I'm using a needle bearing I got form the fan, it's about grammes at 0.40" I used a small 160v 330uF cap to test, and when I fire it, using to bare wires touching them together it's not very good, but when I quickly tap them the projectile shots out, what can I use to stop it from not firing properly? a large switch?
Damn the copper has melted the wire, so I'm going to use plastic.
Forty
Fri Nov 18 2011, 07:09PM
a relay will work for a while to switch it.
a copper barrel will rob a lot of the energy from the projectile because of the eddy currents induced in it.
and if you have too many turns then your inductance may be too high resulting in a longer pulse length, which may be the reason why tapping the wires works better than prolonged contact.
youll also want your barrel to have an inner diameter as close to the diameter of your projectile as possible (slightly larger to allow sliding of course) and have be thin walled so that the coils are as close to the projectile as possible.
Platinum
Fri Nov 18 2011, 07:40PM
So thicker wire and less turns is better?
I'm using a plastic tube I had in my junk box, so that'll work better, the projectile just fits in. But can slide around.
I'm now going to use the 400v 330 UF caps, is is better to have them in series or parallel?
Turkey9
Fri Nov 18 2011, 10:13PM
Parallel for your setup.
Platinum
Fri Nov 18 2011, 11:45PM
So a 56J coilgun, it works it can't go thorough a can which requires 1Joule to go through the bottom. It can kill?
Legit_bacon
Sat Nov 19 2011, 08:17AM
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
from my experiences with my first 60J coilgun, it'll go through a can but id say not cause anyone significant harm. still i'd be careful with the thing
Platinum
Sat Nov 19 2011, 07:54PM
Hmm, is this power enough to make a can crusher?
Also can you make some sort of EMP with these caps?
Thanks!
