  • Guests: 14
Shaun (34)
Spedy (30)
05/01 Shaun (34)
05/01 Spedy (30)
05/02 Adam Munich (30)
Hall Effect Sensors
Part Scavenger
Sun Jul 09 2006, 02:10AM Print
I'm planning on building a a new levitator sometime in the future, what is a good part# for a project like this? (Preferably available at mouser or goldmine). I don't really know what I'm looking for, so any help would be appreciated.
benbradley
Sun Jul 09 2006, 04:13AM
benbradley Registered Member #312 Joined: Mon Mar 13 2006, 01:50AM
How will you use it? The vast majority of Hall Effect sensors are effectively magnetic switches, giving an "on" level when a strong enough magnetic field is detected, and an "off" when a slightly lower field is detected. The demand for those is apparently much greater than for analog.
Here's parts by one manufacturer, though I'm sure there are several others:
There should be lots of data sheets and app notes on that website.
Tesladownunder
Sun Jul 09 2006, 10:27AM
For my levitator, I use Link2 The output is 2.5 V at zero field and goes up or down by 1.3 mV/gauss.
I also used 40 of them in my magnetic field array.
Peter
Sun Jul 09 2006, 05:15PM
Possible idea. Strip down a few dead JVC video recorders.
The capstan motors use a three pin sensor which appears to be a high sensitivity Hall-effect chip with analogue output, runs on 5V DC.
A similar part is also used on the head cylinder, for sensing the FG pulse.
-A
"Bother" said Pooh, as his Gagh attacked him...
Part Scavenger
Mon Jul 10 2006, 06:36PM
Thanks guys! You've come through for me once again.
TheMerovingian
Fri Jul 14 2006, 12:14PM
i used the UGN3509 bought on futurlec for my levitator. They are cheap and very sensitive
Part Scavenger
Sat Jul 22 2006, 05:42PM
Are these hall effect sensors? (pic 3) They look like the ones in the Mouser catalog. The black ones have five pins, and the green and white ones(pic 1) have four. I got some in a goldmine suprise box, others came out of random stuff.
Also anybody know what these three pin devices are? (pic2)
I've checked part #'s on all of these and I get nothing.
1153590173 79 FT12726 Zoom
1153590173 79 FT12726 Picture 040
1153590173 79 FT12726 Pic0001
Marko
Sat Jul 22 2006, 06:05PM
Black and green things in last pic are CF 455kHz filters, can be found in old wirelles phones and etc.
I'm not sure for the white thing but it could also be a filter or two small noise suppresion caps in same package (I have some such things here but with 3 pins, and there are 3 caps inside)
Middle dip-6 ish packages are most likely to be power mosfets or bjt's, I dug out some very similar looking mosfets from old hard drive, but they can also be diodes, hall snsors..
Nothing without designation dead
Tom540
Sat Jul 22 2006, 06:21PM
Tom540 Banned on 3/17/2009.
I think the white thing is an old bar led diffused type. I have something that looks similar it has a few leds in it and it loosk crappy when lit. I don't know what theyed used them for. try and test it with the diode setting on your meter.
Part Scavenger
Sat Jul 22 2006, 06:25PM
Thanks, at least I know what the black things are. The three prong ones came in a goldmine surprise box, and I can't find anything to match the part #s anywhere.
