  • Guests: 29
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Need help with the STM32F4-Discovery board...
Sat Feb 11 2012, 11:47PM
Steve Conner wrote ...
Don't Keil or IAR have a free compiler that targets the STM32? I think the code size is limited, but it turns out enough for most hobby projects.
IAR is what we use at my university.
Linas
Sat Mar 31 2012, 08:42PM
after some time and headache here is some results.
It's just amazing what IAR can do, atollic is just waste of time, same code compiled with IAR runs lot faster than compiled with atollic.
Get 50MHz IO toggle so far, and with atollic can get around 3MHz (PLL and clock settings are the same)
1333226564 1143 FT126188 P1030650
Sat Mar 31 2012, 10:10PM
Linas wrote ...
thats great work Linas, im still trying to get SPI and I2C to work on my F4 and F0.
Linas
Sun Apr 01 2012, 08:34PM
Real time Julia Set fractal calculation with zoom, and other C values as well ,
It looks quite nice :)
Inducktion
Mon May 14 2012, 03:57AM
Hey, Linas, would you be willing to... teach me how to use this thing? I haven't any experience with micro controllers so... yeah.
Linas
Sat Jun 09 2012, 04:41PM
fixed code for SSD1963 and SSD1289 and make touchcreen works (calibration is made by hands)
have working code fro spi flach below lcd, and sdcard with sdio interface
IF SOME KNOW HOW TO USE FATFS PLEASE RESPOIND
Sat Jun 09 2012, 06:00PM
Good luck with the FAT file system, it's a pain in the :-x, especially if you want long file name support.
You can make life easier by only implementing a subset of the functionality. 8.3 filenames and no subdirectories would be a good starting point.
FTDI make a device called the Vinculum. Among its many uses, it converts USB thumb drives to SPI or RS232, and has a FAT file system driver embedded in it.
Linas
Sat Jun 09 2012, 06:32PM
here is my problem
Sat Jun 09 2012, 09:04PM
You mean somebody else implemented the filesystem driver for you and you still can't get it to work? ;-(
Linas
Sun Jun 10 2012, 05:44AM
i used this driver, it should work, but i have no idea why it doesn't work for me
FATFS
