  • Guests: 24
Colin 99 (53)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Good circuit design software
Chip Fixes
Fri Oct 14 2011, 03:12AM Print
Hey everyone, I am in need of a free program that will allow me to design circuits and check for errors. I did a google search but there are a lot of them and I was wondering which ones you prefer. I don't need anything super complicated but I do need something that has a pretty big library of parts.
PSCG
Fri Oct 14 2011, 07:08AM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
ExpressPCB is a freeware circuit and PCB design program. It is very simple to use and offers a large library of components. In the case that you cannot find a specific component in the library, you can design it yourself. Of course, it indicates you the errors in the schematic.
I have been using it for a long time and i'm very satisfied with it.
Chip Fixes
Fri Oct 14 2011, 09:44PM
Ok, thank you very much!
Dr. ISOTOP
Sat Oct 15 2011, 08:59AM
Use Eagle. ExpressPCB, iirc, can only export in its own proprietary format, so you're screwed if you ever want to send the boards to a fab other than ExpressPCB.
Also, LTSpice is your friend for simulation =)
Daedronus
Sat Oct 15 2011, 10:30AM
I'm using the free version of eagle
and
or
for routing
TopoR seems to be the best router I got my hands on so far, and, don't even bother with the eagle router.
KLH
Thu Oct 20 2011, 02:47PM
If you're looking for software that will actually simulate the operation of a circuit, I would recommend LTSpice SwCAD: Link2
This program is geared towards simulation of mixed circuit types, particularly digitally-controlled switching power supplies, but some coaxing will allow you to simulate simple digital logic circuits. Its analog simulation capabilities are very powerful and highly optimized; I use it whenever I have any sort of analog circuit design that I want to test before construction.
The developer, Linear Technology, also makes a few other useful design programs intended mostly for power supply and precision analog design.
As for more advanced schematic creation or PCB design, I agree with others' recommendations of ExpressPCB. I have used the ExpressSCH program many times to make professional-looking schematics, and the ExpressPCB program will actually help you correctly route your own PCB design when you associate it with your schematic. All of these programs are easy to use.
Chip Fixes
Thu Oct 20 2011, 08:15PM
Ok, thanks very much!
earth3
Thu Oct 27 2011, 02:20PM
earth3 Registered Member #3721 Joined: Sun Feb 27 2011, 04:43AM
multisim it is the best in my opinion you got simulator and an extensive library only thing is that you gotta pay or crack it
