Registered Member #3781
Ok I have a 320gb simpledrive and yesterday, when I plugged it into my computer it showed up but when I clicked the usb port to open it, I get an error message: "E:/ is not accessible. The disk structure is corrupted and unreadable." It was working fine a few weeks ago but it is a few years old. Is there anyway to fix the hard drive or do i have to use a software program to recover the files? Thanks in advance for any replies, the drive is our back up drive for the computers so there are a lot of important files on it
EDIT: I have both a Windows XP desktop and Windows 7 laptop
Sorry for the double post but I am just going to use testdisk_win. I hit create a new log file > selected the broken hard drive > Selected Intel > Selected Analyse > and it gives me this image (below) should I do a quick search even though it says no partition is bootable?
EDIT: I did a search, found partition 1, wrote that partition to the drive and then rebooted. It still won't work, any ideas?
Registered Member #2893
Yeah, your MFT is probably fuk'd. What you'll have to do is get the files using testdisk.
* Select the drive and then go to [advanced] Filesystem Utils * Then select your partition, and then select [list] at the bottom * There you'll find the folder structure, where you can browse and copy files/folders off the disk, even if the MFT is corrupted to hell.
ah thank you
EDIT: Any suggestions of what to do with a broken computer hard drive?
EDIT EDIT: Just for kicks, does anyone know what a commercial hard drive recovery would cost if I were to take it into a repair shop? I just need an estimate
Registered Member #96
I would also clone the drive using Winhex NOW just in case it fails completely.
This has the advantage that you have a copy of the entire drive to work on while the original is with the data recovery guys.
If the drive just has a logical failure and is mechanically and electrically OK then cloning has the advantage that the data is copied in its original form. Meaning that even if they quote a ridiculous price for recovery you can then say "No" and use a free tool to get the important data back.
Start with a known clean (i.e. new) drive and copy data onto that. Have done this before and it works even if the original drive has bad sectors... Unlike Windows copy which just falls over in a heap if a single bad file is found.
Try these guys as they have online analysis people.
After I've done as much recovery as I intend to, I disassemble them for the strong magnets in the head assembly. The platters are usually fun to play with too, although be careful, some shatter easily.
EDIT: I usually use linux-based recovery tools. I dump the drive, skipping and retrying bad sectors, with ddrescue (Note lack of underscores; dd_rescue is a different program), keep a compressed image in case I make things worse during recovery, and work on a temporary image. If you can mount the drive directly in a computer it generally works better than trying to work through a USB enclosure; a regular SATA controller is more flexible than most USB MSC, which usually won't even let you do a SMART query.
