  • Guests: 17
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
TC components placement
GODSFUSION
Thu Jun 15 2006, 03:11PM Print
GODSFUSION Registered Member #157 Joined: Sun Feb 12 2006, 08:00PM
Why is all the componnets of the majority of the designs ive seen have everything under the coils? Couldent I enclose the PS, gap an MMC ETC around the primary? Or it all about asthetics?
- wayne -
Philer
Thu Jun 15 2006, 05:02PM
Philer Registered Member #185 Joined: Thu Feb 16 2006, 07:13AM
It reduce the risk of getting components hit by the sparks.
GODSFUSION
Thu Jun 15 2006, 05:12PM
so I could just enclose my components in a lexan case ontop of the primary round the secondary. being enclosed i wouldent worry bout sparks.
- wayne -
Thu Jun 15 2006, 05:48PM
No. Lexan isn't going to stop an arc from hitting your equipment.
Keep the components away from the primary, and especially away from the above portion on the primary.
GODSFUSION
Thu Jun 15 2006, 07:12PM
::sigh:: ya still havent explained why I shouldent.
- Wayne -
EDY19
Thu Jun 15 2006, 07:26PM
You don't want to put it above or around the the secondary because if the sparks are longer than the secondary, that is most likely where they will strike, with the possibility of damaging things.
Dr. Drone
Thu Jun 15 2006, 07:27PM
shades
ragnar
Thu Jun 15 2006, 10:21PM
Something I found most interesting was Derek Woodroffe and Jim Mitchell's friendly mini SSTC competition where they often put the electronics inside the secondary:
http://old.4hv.org/index.php?board=7;action=display;threadid=1129;start=0
These SSTCs have breakouts maybe only 1/3 the length of the secondary, max, but were still very fascinating =)
Fri Jun 16 2006, 11:43PM
Sounds like you havent actually played with any TCs yet? The sparks can capacitively couple right through thick plastic. Remember, this is very high voltage RF. Capacitors act like a low impedance to AC, so the sparks will travel right through (although at reduced intensity). The best way to keep the sparks where you want them is field control. This is something that you sort of get a "feel" for. Basically, keep conductors rounded, and use toroids/spheres where you want to suppress the breakdown of air.
GODSFUSION
Sat Jun 17 2006, 01:24PM
No not quite ive made a twin mot with the voltage doubler n' such, it wasent too impressive. i dont have a lot of experice in "capacitively couple right through thick plastic" types of cases so I wouldent of known.
- Wayne -
