  • Guests: 57
mileswaldron (59)
06/03 mileswaldron (59)
06/04 muze801 (33)
06/05 HVgeek (33)
How to make a simpe railgun that can shoot through paper.
Zack
Mon Feb 21 2011, 08:07PM Print
Zack Registered Member #3624 Joined: Mon Jan 17 2011, 01:08AM
The only railgun I made was terrible, just made of some aluminum stock, and the injector was me pushing a ball of tin foil down the rails with a q-tip. I don't know how to correctly wire a cap bank from flash cameras. I wired the bank in parallel but it always seems to give me less power than one cap. Does anyone know how I can construct a railgun that can shoot through paper at about 1 meter away? Preferably in 2 weeks or so.
Adam Munich
Tue Feb 22 2011, 07:28AM
"it always seems to give me less power than one cap"
I've had this happen before, often it's one bad capacitor in there spoiling the whole party. Test them all and find the busted one, then remove it.
Inducktion
Tue Feb 22 2011, 07:57PM
Or if he's putting them all in parallel won't that lower teh max voltage available?
Zero
Tue Feb 22 2011, 08:54PM
Zero Registered Member #3588 Joined: Sat Jan 08 2011, 11:19AM
Maybe the pulse-time is not high enough.
ESR decreases significantly when putting several caps in parallel.
Btw: Voltage stays the same and capacity adds up.
