  • Guests: 15
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
I have an SCR and wonder if it would work for a small coilgun?
Inducktion
Tue Feb 22 2011, 02:56AM Print
There's the SCR, it says it can handle 500 amps peak, will this work well for a small coilgun? I have some caps that would work okay for it, 250 volt 1500 uf, and some other assorted ones. I need a charger for it, though. Hrm. Does the SCR need a good heatsink as well?
and, would 20 gauge wire work for the coil?
Thanks!
Turkey9
Tue Feb 22 2011, 03:55AM
Play with Barry's sims and do some more looking through the forum, you'll find answers to all your questions.
Since the SCR is in pulsed operation with a very small duty cycle you won't need a heat sink. It won't even get warm to the touch.
Wed Feb 23 2011, 01:32PM
20 gauge wire is too thin, it has too much resistance for coilguns. Try 16ga or better yet 12ga. A coil with one or two layers of heavy wire always works better than with more layers.
I think my RLC simulator will help you come up with a coil design for your capacitors. Look for a discharge time in the range of 2 - 10 milliseconds depending on the length of your projectile.
As he said, a heat sink doesn't matter in pulsed applications. The few milliseconds of heat generated will raise the junction temperature and the energy doesn't have time to spread out to a heat sink before the discharge is over.
My suggestion is to buy an inexpensive SCR like that one (and a spare!) and try it. When you blow up the first one, you've learned something. smile
Cheers, Barry
I can't decide whether or not I like waffles.
Inducktion
Wed Feb 23 2011, 07:11PM
Would litz wire work too? Or am i just over complicating things by trying litz wire?
