  • Guests: 25
mileswaldron (59)
06/04 muze801 (33)
06/05 HVgeek (33)
06/05 jmorlockny (50)
Hybrid Projectile Acclelrator: late production stages, need Advice.
MArked One
Mon Feb 14 2011, 08:09PM Print
MArked One Registered Member #3688 Joined: Mon Feb 14 2011, 07:39PM
Greetings, Ladies and Gentlemen.
I am in the process of creating a 900j railgun with a solenoid (coilgun) injector.
I am using a 12v LA battery, coupled to uzzor's cap charger. ( see Link2
I have assembled most of the components. Now, I just need to troubleshoot the charger to actually work :)
The sequence is thus: the projectile is loaded into the coilgun stage, and the capacitor trio's charge is sent into the coil using an SCR (as per uzzor's schematic) (here Link2 (the whole bank is charged as a whole, but the three caps are isolated by dual relays)
the coil resistance is 2 ohms. Coupled with the 1500 uf, 400v total capacitance i'm using that's 200 A peak. I'm using two p600m (here Link2 ) diodes as protection. My first question: are the diodes fast enough to block the reverse transient?
Then, the projectile moves onto the rails, where it acts as a switch in itself. The remaining 750j (10340 uf, 390v) is discharged into the rails. My other questions are thus: what kind of peak current can I expect from the railgun arrangement? What kind of diodes do you recomend me to use, to defend the device from the subsequent reverse transients? My final question: what can I employ, to protect myself, if one of the caps shorts at full charge? some sort of device accross the caps?
EDIT: I can't seem to make the url's work, can someone help out?
Kind Regards,
Ivan Kozlov
Tue Feb 15 2011, 06:10PM
The P600M diodes are 'standard' so recovery time will be around 1 to 5 us, which should 'catch' the coilgun back-emf ok.
The peak current for the railgun part will depend mainly upon
- Total circuit resistance
. .Capacitor bank esr,
. .wiring resistance,
. .'resistance' of the rails/projectile short-circuit
AND
- Total circuit inductance
. .Capacitor bank esl
. .Wiring inductance
To add a URL I just 'copy' the URL then 'paste' in my post,
leaving a space at the front and back of the pasted URL
like this Link2
MArked One
Tue Feb 15 2011, 07:17PM
Thanks for your fast reply.
how do you measure capacitor esr? I have seen several meters that do it, but have never invested in one...
But back to protection: what can i use, to protect the bank from reverse charging and shorting out?
Saz43
Wed Feb 16 2011, 05:40AM
I'm not sure how to measure it, but the data sheet for a capacitor usually will give an ESR value.
MArked One
Thu Feb 17 2011, 08:34PM
Greetings.
The esr seems to be 400 mohm-ish.
The main question is cap bank protection from shorted caps.
I can always add more reverse diodes, but I cannot sew my hand back on, if one of the caps decides to get capricious :)
MArked One
Fri Feb 18 2011, 07:24PM
EDIT: Oops, please delete post
