  • Guests: 22
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Building a linux cluster
Dr. Shark
Thu Jan 27 2011, 12:47AM
Double posting like a boss:
1296088906 75 FT106644 Cluster1
got the first bunch of components today...
1296088906 75 FT106644 Cluster2
starting with the RAID node, which was completely dead at first. Turned out the memory was DOA, which took me a couple of hours to figure out.
1296088906 75 FT106644 Cluster3
The compute note went together smoothly, installing Ubuntu from a flash drive takes only 20 minutes. Impressive stuff!
1296088906 75 FT106644 Cluster4
both machines ready to rock and roll! The blue screen is the raid controller which has it's own BIOS. It's initializing the 8TB array, which unfortunately takes 5 hours.
1296092509 75 FT1630 Rad
Once I can get some software on the RAID and test everything is working as expected, I will order the remaining 8TB of disks and three more compute nodes.
Josh
Wed May 18 2011, 07:10AM
Josh Registered Member #938 Joined: Sat Aug 04 2007, 05:39AM
Interesting stuff.
I've had some interest in doing a dual i7 computer utilizing the 2600K i7's because it seems over the years rendering, comping and such with Blender is becoming a rather addictive hobby of mine.
Since CUDA and OpenCL is rather young I've been thinking CPU power.
Anyways good luck with the cluster,
I'll definitely keep reading your thread.
