  • Guests: 45
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
What is wrong with this line of code?
big5824
Sat Dec 11 2010, 10:54PM Print
I am currently writing a C program for my uni coursework, and am having a lot of trouble with this code. It is exactly the same as the material we were given, and works in C++, but throws "syntax error before *" when compiled as C.
void set_base_values(student_info *pointer) //error is thrown here
(*pointer).maths_1.mark = 0;
(*pointer).maths_2.mark = 0;
where the student_info struct is defined at:
struct student_info
struct module maths_1; //module is just another struct template
struct module maths_2;
and declared at:
struct student_info student;
The idea of the top function is that i can pass it the memory address of a struct of type student_info, which it will then set certain values within.
Help is greatly appreciated, I have to have this cracked by monday cheesey
Nicko
Sun Dec 12 2010, 12:40AM
I suspect its because C++ implicitly typedefs defined structs with a name the same as the struct, whereas C, being older, doesn't do that for you automatically.
I can't remember the exact syntax, but in the instantiation of set_base_balues, you'll need to change it to:
void set_base_values(struct student_info *pointer)
 /* stuff */
Cheers
big5824
Sun Dec 12 2010, 12:52AM
Perfect :D thank you very much :)
