  • Guests: 19
a.gutzeit (63)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Mini SGTC
Avalanche
Sat May 27 2006, 09:29PM Print
This started off as just a quick 'something to do with my flyback'.
I have become totally hooked now, and I have been playing around and improving this coil all day, and plan to build it into a proper coil eventually, so I think it deserves a thread on the project board! It's my first SGTC, after building several solid state coils. I can't believe how noisy even this small coil is, how do you guys cope with large coils cheesey
fRes = Approx 1.2Mhz
Tank Cap - 5 beer bottle caps (about 5nF?)
Primary - tapped at 6 turns
Secondary dimensions - 35mm diameter, 75mm winding length.
Topload - Foil covered table tennis ball
Anyway it all started out with a single beer bottle cap, and I noticed I was getting the most output with the maximum number of primary turns, so I simply started drinking more beer and slowly adding capacitors. I am now up to 5 caps, still tapped at the furthest turn - so I think it can do more!
Coil is running from a ZVS driven flyback, and has a 2 spark spark gap (whatever that is called!)
The setup has already been through a number of revisions, and I'm on my second ZVS circuit. See below for pic of latest setup, and a video. The post I made in the 'add your tc here' thread is already out of date...
The coil is doing about 4" to air, even though it looks less on the photos angry
Any suggestions on how I could improve it would be most welcome smile
Latest Video: 1.3MB MPEG1
1148764936 103 FT0 Tc Setup
1148764936 103 FT0 Tc Output
ragnar
Sat May 27 2006, 11:01PM
Aw, he's cute, Avalanche. I saw it last night in the "Post your TC here" thread, but no sparkies =P
I reckon you could improve it by constructing a rolled cap (for size reasons, compared to the bottle cap), lying it down next to the flyback, and bolting it all down to a nice little board. Mini SGTCs just don't have the charm unless they're portable and neatly finished (like your other coils wink)
Are you losing much in the way of corona off your bottles? If so, for efficiency, perhaps you'd consider some corona rings.. =)
Wow, just saw the video - there's a lot of corona there! How does he perform with a single breakout point on the topload?
Marko
Sat May 27 2006, 11:32PM
My first TC ever was too a miniature SGTC.
It was powered by NE555 ignition coil driven from 12V (I didn't even have an adequate power supply), about 10kV, and it gave some 5cm sparks at maximum (but very hazy and barely visible).
Later I tried few times with flyback but I never got into something more than aligator clips and bunch of bottles on the table.
I hope you aren't going to build some 30nF cap this way. cheesey
Actually you don't have some special restraints in choosing tank cap since you are charging with DC.
For more bang energy you can simply set the gap more loosely so the cap charges to higher voltage.
Maybe you can later play with resonant charging, different cap types (MMC; rolled) etc.
It looks much less than that, it seems like 10cm arc would probably engulf secondary completely confused
For what I can tell sparks seem to be about 5-6cm long in the movies.
One thing I was dissapointed with samll SGTC's is that they seem to be quite poor EF transmitters. I could weakly light up neon bulb only by drawing an arc with it.
Resonators also didn't respond at all.
Mike
Sun May 28 2006, 02:04AM
Awesome coil Avalanche, it is a beauty!
The primary and secondary together look great, and a cool arc picture. For a new cap may I suggest Polystyrene Plate capacitors
I have been hoping someone would test em on a SGTC, and these might just be what you need.
Well good job!
-Mike
Avalanche
Sun May 28 2006, 10:54AM
Thanks for the comments smile
wrote ...
wrote ...
Yes good suggestions for new capacitors. I will experiment with a rolled cap and plate caps (or similar), and post my results. The setup is very lossy, if I disconnect the coil and power up the flyback, everything hisses and it stinks of corona. I guess eliminating that would help! Might try an MMC also, I have some small caps but I'm not sure on their voltage.
wrote ...
lol, I'm getting close. I'd better sober up before I wind the new secondary for that cap cheesey
wrote ...
Here's a few new pics, first up is a screw as a breakout point. The behaviour of this coil is totally different to any of my sstcs! The corona looks like it is liquid flowing off the top of the screw cheesey
The third photo is interesting, if you have a look at the full size photo you can see arcing between turns on the secondary! The voltage rise must be huge, it must take at least 1kv to do that? rolleyes
1148813571 103 FT10264 Single Break
1148813571 103 FT10264 Composite Blue Medium
1148813571 103 FT10264 Arc Between Turns
Marko
Sun May 28 2006, 11:43AM
I like your streamers, especially in second pic. Mine were a lot thinner and hazy, probably because coil wasn't tuned properly.
I did also figure out that bottle caps are especially bad for low power because of corona losses.
It seems that you are already overpowering the coil since racing sparks are occuring.
You can maybe try bigger topload to prevent this.
Self Defenestrate
Sun May 28 2006, 03:04PM
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
For the between turn arcing, I would suggest finding some acrylic tube to fit over the secondary, sealing it in with hot glue, and filling the space inbetween with oil. I had beaten the secondary on my 1kv coil until it had no output from arcing to itself, but the oil fixed it up and it works great now. Your topload reminds me of TDU's 18 inch coil, but without four mot's worth of power behind it.
Marko
Sun May 28 2006, 03:11PM
Noo cry It would ruin the nice coil, and especially oil would be very messy, maybe poliester or epoxy would do if it's really necessary.
Since coil is not CW it will hardly set itself on fire or damage the top of secondary severely.
you can give it few more coats of poliurethane if you are really afraid of blowing it up.
Avalanche
Sun May 28 2006, 03:47PM
Yeah it doesn't appear to be damaging the coil, so I will probably leave it for now.
I've been constructing roll up caps anyway, but I am not having much luck sad The caps themselves are working really well, it's just that I don't have a clue as to their capacitance.
The one I'm using at the moment is about the size of an AA cell, and is made from 2 strips of aluminium foil, and 2 strips of overhead projector transparency. It seems to be tuned to the coil, in that altering the tapping on either way decreases output, but the output itself is anly about half an inch neutral I guess the coil is probably tuned to a harmonic.
At a very rough estimate, how would these caps compare to beer bottle caps in terms of capacitance? I get the feeling this cap is probably about 10nF maybe?
I made a really huge roll up cap, and the spark gap sounded like a machine gun with it connected cheesey It must have been about 100nF cheesey
Once I sort out a capacitor I will start building this coil onto a base.
1148831248 103 FT10264 Img 2458
Sun May 28 2006, 06:23PM
If you know the thickness of the plastic, and its dielectric constant (you can look it up), then you can figure out the capacitance.
C = (K*Eo*A*N)/d
K is the dielectric constant (around 2.0 for PP/PE).
Eo is the permittivity of air = 8.85 x 10-12 F/m
A is the plate area
d is the thickness of the dielectric.
N is the number of plates - 1 (so for a rolled cap, N = 1). Or the number of dielectric "plates", if you like.
Hope that helps.
