  • Guests: 62
06/19 sio2 (51)
06/20 Sparrow338 (36)
06/20 oxodoes (35)
SCRs
Tue Nov 23 2010, 07:06PM Print
I hope someone in this section can point me in the right direction.
I am looking for a SCR, 600vac @50A
I will be pulsing it somewhere between 10-30khz
What models would work and where could I get some? Hopefully, my next question will be a post on the sale/trade board once I know what I need.
Neuuubeh
Tue Nov 23 2010, 08:57PM
Neuuubeh Registered Member #3411 Joined: Sat Nov 13 2010, 08:25PM
SCR at 10-30khz? You can forget it I believe. Once switched on, an SCR turns off when current flowing through it drops below a certain threshold. Its fairly difficult to extinguish the scr... 50A isnt much either..
What you are looking for is probably an IGBT. Or a high powered MOSFET. Then again, its hard to switch AC current with just one semiconductor, you will have to use two of them?
Maybe i misunderstood your post?
Tue Nov 23 2010, 10:30PM
If I have to use two or four that is fine. I would prefer a half-bridge setup as this is easier. I want to make a scr power controller. I know they are used for industrial power control for an induction heater.
Maybe I am using the wrong switching frequency.
I have already built an igbt converter. I think a scr would be better.
So, not knowing much about SCRs, what model would I need?
Pinky's Brain
Wed Nov 24 2010, 03:46AM
Just curious ... what do thyristor inverters have to do with electromagnetic launchers?
PS. their use in industry is mostly because of legacy ... if the cost is not a factor (and at 50A it isn't) IGBT designs are just plain better.
Wed Nov 24 2010, 04:43AM
I was told that many coil-gunners use them.
I will probably use igbts, but I wanted to see if scrs were worth pursuing.
Wed Nov 24 2010, 05:58AM
SCR usually are design for mains frequency, (50-60Hz) You'll probably have trouble finding one fast enough for your 10-39KHz
Wed Nov 24 2010, 11:13PM
But, i have some experience with the SK065K SCR, it is 1kv and 65-70 amp (i guess that depends on the lead style). 950 amp is the peak pulse, which i have use 5 parallel sk065k's to switch an 800v 1950uf bank into a dead short with short wires with no problem at 1.5v on the gate (D cell).
