  • Guests: 13
cbfull (52)
Steve Ward (39)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
YAG Power Supply
Hazmatt_(The Underdog)
Tue May 23 2006, 10:57PM Print
I got a power supply from college along with about 40lbs of glass and some other power supplies too. I just wanted to post some pics so you guys can see what the guts look like. I think its really interesting.
The design uses a lot of the Wima caps for its pulse forming networks rather then large heavy doorknobs. I want to reverse engineer it, but that will take a massive amount of time.
enjoy.
1148425071 135 FT0 Mvc001f
1148425071 135 FT0 Mvc002f
1148425071 135 FT0 Mvc003f
1148425071 135 FT0 Mvc004f
1148425071 135 FT0 Mvc005f
1148425071 135 FT0 Mvc006f
1148425071 135 FT0 Mvc007f
1148425071 135 FT0 Mvc008f
1148425071 135 FT0 Mvc009f
1148425071 135 FT0 Mvc010f
1148425071 135 FT0 Mvc011f
1148425071 135 FT0 Mvc012f
1148425071 135 FT0 Mvc013f
1148425071 135 FT0 Mvc014f
1148425071 135 FT0 Mvc015f
Tue May 23 2006, 11:03PM
wow, nice find!
I wonder what happened to the laser head confused
Any plans for it?
Eric
Tue May 23 2006, 11:37PM
Eric Registered Member #69 Joined: Thu Feb 09 2006, 07:42AM
Pretty cool, lots of good components in there! I got bits of a few supplys that must have been made by the same mfg, lots of french made stuff. I've still got the flat bleeder resistors, those neat Garnier HV relays and a few of the big red epoxy potted blocks. I'd be curious if you figure out what's in the latter, I thougth they might be flybacks / xformers but without the circuit they came from I couldn't tell for sure.
Wed May 24 2006, 02:02AM
I know at least one of the blocks is a pulse transformer because of the SCR network, the center tapped ground, and the output leads. Some of the others are going to take some real guessing. One has heavy leads and a feedback output so it could be a CT or a choke with a feedback winding. Hard to tell I agree!
I hope I can get a laser head for it someday. I'm down two parts really, the circulator/sump and the head, but that's about it. I do need to replace the fans that were scrounged out of it, and get one of the control/interlock cables I forgot, but after that, she'd be good to go.
Next issue... I don't know what a YAG laser does. Guess that means I have to read Sam's laser faq huh.
