  • Guests: 17
BlakFyre (36)
SENTRY (31)
05/01 Shaun (34)
05/01 Spedy (30)
05/02 Adam Munich (30)
Diable Tonnere – my latest project.
1 2 3 4  last
Wed Aug 19 2009, 07:58PM Print
Daniel Uhrenholt Registered Member #125 Joined: Fri Feb 10 2006, 01:52PM
Hi Folks,
This week I will start on a new DRSSTC, and it will probably be the biggest I will ever build.
Some specs:
500nF primary capacitor
One secondary coil 200*920mm AWG ??, I got this coil from Finn + a toroid similar to the one I designed for Thumber, but a “little” smaller, so the Fo should be around 40kHz.
A trusty full bridge(the one I use at the Universitarium in Aalborg)
3 phase power
I just started drawing the parts in SolidWorks, and hopefully I can start CNC milling the parts sometime next week. So the first pictures you will se is a 3D rendering of the coil.
There is not much new to this project, as it's only the mechanical part I need to do, and the driver is Finn Hammer's design...
I`m hoping for 2meter+ sparks:-)
Project goals:
It has to be a cool design smile
It has to be driven without a breakout point, so a lot of decoupling in the primary circuit, and a lot of strike rails...
It need to be mounted upside down (I need this for a show sometime in November)
It has to be easy to take apart, and setting up where ever I go...
Higher power audio modulation is a must wink I just finished my MIDI interrupter this week Link2
And it has to be done before Cambridge Teslathon... So just a little stress from the beginning:-)
Cheers, Daniel Uhrenholt
Mon Aug 24 2009, 07:15PM
Hi Folks,
I did some drawing this afternoon, and I think it turned out really nice:-)
This is just the overall design, I have some other ideas regarding the primary coil, that I want to move up and down easily to change the coupling. And a nice way to mount the secondary coil, without having to screw it all together, just put it down the middle and turn it for a little click, and I will be ready to make sparks all day long smile
I'm a bit stressed this week, so the final design will be made next Monday...
I know that the strike rails on the drawing will act as shorted turns, but it was the easiest way to draw it like that smile
1251141050 125 FT74660 Primaer
Oh yes, the primary will be a pain in the a** to wind...
Mon Aug 24 2009, 08:17PM
Naming it after a Haitian Loa is wicked indeed.
And making it unnecessary complicated is also very wicked.
You have my attention.
Cheers, Finn Hammer
Marko
Mon Aug 24 2009, 10:11PM
Daniel,
This is easily one of most badass looking primary coils I've seen... Although it's easy to be made jealous by CNC machining! :P
Is the secondary indeed going to be entirely corrugated like shown on the drawing? Is the winding going to be inside some sort of a plastic pipe?
Looking at that primary I feel like some copper tube grading rings on the secondary and a multi-ring toroid (themed like the primary) would be more fitting in appearance... Just cake care for the Rule of Cool not to make your design impractical! :P
Cheers,
Marko
Mon Aug 24 2009, 11:20PM
If you're going to run it 'upside-down' would a spherical 'bottomload' be better?
Lovely rendering of the primary.
Tue Aug 25 2009, 03:57PM
Hi Marco,
The secondary is placed inside a really neat PVC pipe that Finn helped me to get, it's the same as he used for his V twin.
And of course it need a multi-ring toroid wink
1251215643 125 FT74660 N852894795 379611 9641
The only problem I have, is that I don't have the time it takes to make it now, and neither the money for having the parts laser cut...
Sulaiman,
Probably, but why bother when it will work just fine with a toroid smile
Cheers, Daniel
Fri Nov 20 2009, 10:10PM
I'm back on the project:-)
Now the plan has totally changed, as I would like to change the tapping point when the coil runs, and also change the coupling. This is a really big project, but I am almost done with the CAD model of the primary, and I will start CNC milling the parts tomorrow morning.
CAD model of the primary and pictures of some of the parts will be posted tomorrow.
Cheers, Daniel
Sat Nov 21 2009, 03:04PM
Hi all,
Today I made the first part of the primary holder, but it is actually 10 smaller parts that fits nicely like a puzzle.
Here is some pictures:
1258815713 125 FT74660 Img 2099
1258815713 125 FT74660 Img 2100
Unfortunately I had to leave the shop early, because of the annual Christmas lunch in the local Taekwondo club. But tomorrow I will make some more parts, and hopefully sometime next week you can see the primary holder...
Cheers, Daniel
Thu Nov 26 2009, 09:32PM
Hi all,
Today I milled some nice Tufnol spur gears for the secondary lifting system:-) Tomorrow I will mill the rest of the parts, and sometime Saturday I hope it all will be done... But there is still a lot of work to do.
1259271045 125 FT74660 Gear
Cheers, Daniel
rp181
Thu Nov 26 2009, 10:02PM
thats awesome! do you do it manually, or use a CNC?
BTW, great machining on the primary holder, can't even see the seams.
1 2 3 4  last
