  • Guests: 27
Dalus (34)
Kizmo (37)
05/22 Skynet (32)
05/22 syntroniks (15)
05/22 Powerfulman (27)
H-Bridge (World's Largest?)
Jrz126
Mon Oct 04 2010, 01:34PM Print
The Parts:
1286197204 242 FT0 Parts
The eletrolytics are 2400uF, 450V.
The decoupling caps are 4uF, 1500V
Oh and the igbts are only 2400V, 1200A rms.
First task was to fix the heatsinks. I got the pair of them from ebay for $50 a few years back. They're 16"x10". This is probably why they were so cheap:
1286197300 242 FT0 Heatsinks Before
Dave Marshall lives nearby, and his friend John was able to machine them pretty good. I had to clean them up a little bit with a sander.
1286197300 242 FT0 Heatsinks Machined
I used some 1/2" copper pipe that I smashed flat with a hammer. A little primitive, but a heck of a lot cheaper than buying bar stock.
1286197300 242 FT0 Copper
half of the electrolytics
1286197833 242 FT0 Electrolytic Bus
Decoupling caps installed. This complicates the assembly a bit, I need to remove 6 of the electrolytics to connect them.
1286197881 242 FT0 Snubber Installed
The H connection:
1286197904 242 FT0 H Conn 1
Just need to make the bus bars that will connect the electrolytic caps in series.
1286197928 242 FT0 Almost Done
I have it all broken down right now. Going to clean everything up real nice and make the final assembly.
The bridge will mainly be used to drive a DRSSTC, but it'll be easy to drive other things with it.
dmg
Mon Oct 04 2010, 02:12PM
Holy Crap!!!
this is without a doubt the largest DRSSTC bridge to my knowledge
do you have a secondary yet?
Where did you get those bricks from?
Killa-X
Mon Oct 04 2010, 03:00PM
Would have to agree. That looks like the biggest halfbridge I have ever seen, looks good!
I would like to know what size secondary you are planning to use with all of that power =) Let us know! Else, looks good and keep up the good work =D
Jrz126
Mon Oct 04 2010, 03:25PM
I do have a secondary and topload built:
1286205274 242 FT97868 Me With Coil
the coil is 12.5" diameter, ~40" tall. Resonates at 34kHz IIRC.
Still need to build the primary. not really looking forward to it.
I have my sources for the bricks. (I sit right next to the Power Electronics engineer. He lets me know whenever there is scrap material - Scrap being anything that isnt usable for production).
oh and its a full bridge. not half.
ScotchTapeLord
Mon Oct 04 2010, 03:39PM
Wowzers... definitely the largest hobbyist H-bridge I've seen. The fact that there are IGBTs of this size implies that there probably are bridges of this size out there and the fact that a hobbyist was able to get hold of a bunch implies there are probably even bigger ones out there... somewhere. So, probably not the "World's Largest" but still runs circles around non-commercial bridges.
I'm really excited to see what you do with this!
Have you given thought to the MMC? That's going to be a bank-buster!
Jrz126
Mon Oct 04 2010, 04:48PM
I have 200 of theses:
1286210014 242 FT97868 Caps
They're the GE 42L series. 1200V, 0.68uF each. They aren't the 942C's that everyone loves, but they worked ok in the OLTC. I think I only paid $80 for all 200.
Yes, there are more powerful bridges out there. The IGBTs dont get much bigger than this though. The only larger IGBTs I've see/heard about is 3300V, 1700A RMS in the same package size. I'd guess that if you went larger, you'd have a hard time keeping the junction temp(s) down.
The larger bridges have multiple bricks in parallel for each switch.
teravolt
Mon Oct 04 2010, 07:26PM
Hi Jrz126 thats a sweet coil, can't wate to se the results. Can anybody get the price on those through a desributer or is your source for theas caps private.
ScotchTapeLord
Mon Oct 04 2010, 08:14PM
Yeah... MMC is proving the hardest hurdle of my coiling adventures... You are most fortunate!
Jrz126
Mon Oct 04 2010, 10:36PM
This is where I got the caps from back in 2006: Link2
Coronafix
Mon Oct 04 2010, 11:50PM
Did you ever get that coil working as a OLTC?
Are those IGBTs fast enough for what you want to do?
What will your power source be?
Might need some decent cooling if the bricks aren't fast enough.
